![]() Join Date: Mar 2000
Rubber spacer between rear axle/springs
Is there a replacement for rubber between leaf springs and axle pad? I assume it is supposed to be there. Or what else can I use to replace or dimensions if replace with steel plate for a bit of lift.
Any info on this would be appreciated. Thanks Posted via Mobile Device |
Re: Rubber spacer between rear axle/springs
I have never seen anything between a leaf spring and a spring perch, I wouldn't want anything in there either.
SKINNY TIRES RULE!
I've heard horror stories about people using hockey pucks as lift blocks. Could it be some type of homemade lift? Do you have any pictures?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
One of the First
![]() Join Date: Jan 2000
I've been looking for replacement for years. White plastic ... I cut a bleach bottle one time.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Mine had some pads originally also, thought they were maybe Teflon or something like that. I used the tops off a plastic margarine tub and cut them to size. Some sort of anti friction pad I figure.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Mine are about 1/4" thick in squeezed in a steel C shaped cradle. There is a ring that slides on a hole in middle that slides into spring perch pad and the spring bolt goes in it for alignment.
I don't know if it is proper or not. Posted via Mobile Device |
#7 | |
Can you post a pic of what you have? It's been several years since I've done mine and to the best of my recollection that is not what I had.
Here is a pic. I think the other side is cleaner. Will take it tomorrow.
![]() Join Date: Nov 2007
Rubber or plastic spacer or pad is a new one to me. You should have zero movement, or friction, between the leaf spring pack and the axle perch. I personally wouldn't run anything like that on mine. If you want to lift the rear end properly, you really have four options: a lift block (made of steel), 1" Zero Rate that attaches directly to the spring pack, add a leaf, or a full on set of lift springs.
Definitely NOT what I had. That is interesting, would actually give you a small lift. Maybe someone added that because the springs were sagging.
I would remove that rubber. How do you tighten the u-bolts properly with that rubber pad compressing the entire time? May be an old aftermarket piece. Not around anymore for a good reason. Loose u-bolts = trouble.
