prebent brake lines
I'm looking for a set of nice fitting pre bent brake lines that run from the Master Cyl - prop valve to front & rear brake lines. I live in Michigan & InLine Tube is here but Has a bad Rap from some of the guys around town. I have seen them hand bent but prefer the factory look. I have a 66 GMC But I'm Running a 72 Manual Brake master & discs up front & Drums in the rear. I have scoured the archives but found nothing. thanks for any help. photos would be nice if you have'em !
2WD Jimmy
![]() Join Date: Mar 2005
Re: prebent brake lines
[QUOTE= I live in Michigan & InLine Tube is here but Has a bad Rap from some of the guys around town.QUOTE]
Hmmm... I have the Inline Tube set and it is quite nice. |
One of the First
![]() Join Date: Jan 2000
Order all my replacement brake and fuel lines from in-line tube. You will have to straighten a couple out (bent for shipping). But, ensure that you know what you are ordering. Alot of folks order the wrong application, then have a bad experiece trying to figure it out.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
![]() Join Date: May 2007
I have purchased several complete sets, of brake and fuel lines from Inline Tube. Everything fit fine.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Well thats all i needed to hear ! Looks like im taking a field trip this week ! Thanks guy's. Will post how they turn out. I will go there and order in person.
I have bought front ss prebent before and was quite happy with the product. Im working on the back brakes now and plan to order the rear lines. Plenty of people on this forum have used inline without problems, you have the advantage of being somewhat local, if you do have problems
Nice shoebox!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
