09-07-2013, 04:13 PM | #1 |
WTB a crappy/incomplete under hood harness...
All I'm needing are the two fused wires for the voltage gauge and the temp sender wire - if you have a ratty harness that includes those pieces let me know.
Thanks! |
09-08-2013, 12:23 AM | #2 |
Re: WTB a crappy/incomplete under hood harness...
Let me check i might have 1
09-13-2013, 09:30 AM | #3 |
Still looking...anybody?
09-13-2013, 06:23 PM | #4 |
I think I still have my old harness. I'll look in the garage tonight and let you know tomorrow. It's complete but ratty like you are looking for.
09-13-2013, 06:29 PM | #5 |
09-13-2013, 10:42 PM | #6 |
I have at least 5 or 6 of them, 20 bucks plush shipping for the whole harness.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
09-14-2013, 09:12 AM | #7 |
09-15-2013, 01:06 PM | #8 |
Well I checked out all my less than desirable harnesses and all I have is the harness with the two fuses for the volt gauge. The temp sender wires have all been toasted cutup or missing.
My suggestion is to just build yourself a new temp sender gauge wire. I have a friend who gets all the connectors new through a hardware electrical supplier of his. I have done that several times. So find a auto shop or upholstery shop that also does electrical repairs and they should be able to get you the connectors. Now the fused wires all look to be fairly good, some scuffing of the plastic coating and it is showing some exposed wires on the small section that goes from the junction block by the battery and plugs into the first fuse holder above the battery. I have to get batteries for my camera so I can get a picture for you.
09-15-2013, 01:39 PM | #9 | |
09-15-2013, 07:26 PM | #10 |
How about this deal just to save me from two trips to the post office.
I have it boxed up and it is slightly smaller than the medium "if it fits it ships" box. USPS list it as $12.35 and my experience is it is cheaper by a few bucks in a regular box. I'll do it for $30.00 total If you can get me paid by paypal by early AM tomorrow it will be on its way. I PM you with payment info. Thanks Brian
09-16-2013, 10:32 AM | #11 | |
Honestly, since we're now talking about a harness without the temp sender your price seems a bit steep - if I'm going to make the temp sender wire then I may as well make the two fused wires also. Thanks for your time. Jerry |
09-16-2013, 11:30 AM | #12 |
Ok
09-17-2013, 08:15 AM | #13 |
Still looking was going through more stuff and found 1
09-18-2013, 12:30 PM | #14 |
Here are pictures of 2 not sure what you need
09-18-2013, 02:25 PM | #15 |
Could you email those pictures to me? I need a bit more detail....
Jerry |
09-18-2013, 04:15 PM | #16 |
Do you need both ?
09-18-2013, 04:32 PM | #17 |
Send the clearer one.
09-20-2013, 10:02 AM | #18 |
Got the pictures - my old eyes are having trouble with them though.
In the pic with the temp sender wire I can see the wire but it doesn't appear to have the connector on the end of it. In the other pic I can't make out the two fused wires that go into the firewall connector at the two spots above the 12 gauge red wire on the right of the connector (looking at it from the engine side). |
09-20-2013, 06:20 PM | #19 |
Yes the temp wire is there needs a conector end put on it also both inline fuses are there
