![]() Join Date: Jun 2007
rear suspension question
I have a '71 K5 that needed rear wheel cylinders. when I went to change the left rear cylinder lo and behold the spring retainer plate was in three pieces. So I need to replace the left rear spring retainer plate. It is the plate that the U bolts pass through to hold the springs to the axle. Never had one break. I have not been able to find one. I checked parts houses even one's not dedicated to chevy's and blazers with no result. HELP!!!!
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: rear suspension question
Post a picture I might have one.
Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
Here is the pic.
Hold the presses! Found a great set of 4x4 Rear Cast Iron UBolt Saddles at Manes Truck Parts, MO. Both Ron and Tracy were very helpful and....they had the parts. Wow! Soon "On the road again".
I would imagine they would make universal ones. You might could even get one at a trailer supply store. That's where I got my u bolts for my lift kit. I would try the classified section. That would be an easy part to ship and the guys on here are pretty helpful. Good luck.
~ It's a Learning Process ~ Click Here for my Blazer Build: 1971 Blazer 4x4 Click Here for my Work Truck Build: 1970 C10 LWB Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F |
I do have some if Manes falls through. Glad you found some. Good Luck.
Richard
I bought these aftermarket ones
http://www.autoandtrucksprings.com/p...ng-1747-0.html Posted via Mobile Device
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
