Old 09-10-2013, 07:05 PM   #1
Layrokr
Layrokr's Avatar
70 Front Crosssmember With After Market Disc Brake Conversion
I have a 70 front cross member which has been modified as well as the factory a-arms which have been modified by a local shop. (The Drop Shop)
The a-arm modification gives them a 2 inch drop. New ball joints were installed along with the aftermarket disc brake kit. The kit was installed then sat in a shop for over a year. There is some surface rust on the rotors and one of the rubber ball joint cups was damaged. Springs are factory and I believe they were cut by the previous owner. I would like $600 for everything. I can send pics if you are interested.
Layrokr is offline   Reply With Quote
67 - 72, disc brakes, swb
