Old 09-23-2013, 11:48 AM   #1
ratty65
Help with front steering stops and bags
So my burb has been bagged for most of the summer now and when I did the front I didnt pay too much attention to the steering stops. Now that Ive been driving it more Ive noticed that when all aired out the bags rub a little on the steering stop on the bottom control arm. What have you guys done with this? Has anyone cut them down or removed them enough to avoid clearance issues. BTW its a 1971 C20 running 2600's up front. Any suggestions or tips would be appreciated.
ratty65 is offline   Reply With Quote
Old 09-24-2013, 12:06 PM   #2
ratty65
Re: Help with fron steering stops and bags
I know there's a lot of you guys here with bagged suburbans. Is anyone having similar issues with rubbing on the steering stop? Can I trim it without having any issues with my steering?
Old 09-24-2013, 02:14 PM   #3
vectorit
What?
vectorit's Avatar
Moved from Suburban area to suspension in hopes you will get more feedback on your question.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-24-2013, 05:31 PM   #4
Pro Performance
Pro Performance's Avatar
It is best to remove these, and most guys will do this. You will want to make sure the bag doesn't rub on anything, even when aired out, as over time it could cause a failure.
You can always fab up a new, slimmer, steering stop if needed.
- Travis
Pro Performance is offline   Reply With Quote
