Old 11-05-2013, 07:06 PM   #1
bsteele
My '69 c-10
Here is a picture of my c-10 after I dropped it another 2". Total drop now is about 5 in the front and 7 in the rear. I think I am going to go another inch in the rear.Name:  truck.jpg
bsteele is offline   Reply With Quote
Old 11-05-2013, 07:25 PM   #2
Ole Greenie
Ole Greenie's Avatar
Re: My '69 c-10
So, this begs the question....C-notch?
It looks like from the pics that you have trailing arms...right? I did a 4" drop in the rear of mine and I am always hitting the bump-stops, even with new quality shocks all around.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 11-05-2013, 07:39 PM   #3
bsteele
Re: My '69 c-10
Yes it does have trailing arms. I have the notch, just have not put it in yet. I had 5" drop springs on the rear and never hit the stops. Still have about 2" of clearance from axle tube to frame. I still have to set the front end and re-center the rear end before I take it down the road.
Old 11-05-2013, 07:49 PM   #4
Ole Greenie
Re: My '69 c-10
My rear drop is 4"...no C-notch...and I still hit the stops. Hmmm...I have 18" wheels which should not affect the axle distance to the bump stops. I have "maybe 2 inches" between the bump stops and the axle tubes.
I'm thinking of cutting the bump stops down to give me another inch of travel so it doesn't hit. One thing for sure...I can't drop it 7". My total drop is 3.5" F and 4" rear. I'll post pics in a few....
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 11-05-2013, 07:59 PM   #5
bsteele
Re: My '69 c-10
Sounds good. I would like to see it. I cut the bump stops off when I put the blocks in the other day. They had to go for the c-notch.
Old 11-05-2013, 08:27 PM   #6
Ole Greenie
Re: My '69 c-10
Okay...So here is the clearance I have with a 3.5" and 4" drop and I still hit the stops in the rear. Front has no issues...
Should I cut down the bump stops?
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 11-05-2013, 09:07 PM   #7
bsteele
Re: My '69 c-10
I don't know. I don't have much travel in the rear of my truck. It is pretty stiff.
Old 11-05-2013, 09:19 PM   #8
Ole Greenie
Re: My '69 c-10
Hey B...Thanks for all the info. Much appreciated! It helped me understand what I have and which direction I need to head going forward. GO DAWGS!!!!!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 11-05-2013, 09:20 PM   #9
ksshane
ksshane's Avatar
Re: My '69 c-10
you can cut down the bump stops. They even make these little mini bump stops I got a couple from DJM with a kit I bought from them. They are only about an 1" tall if even that.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 11-05-2013, 09:40 PM   #10
Evaded
Evaded's Avatar
Re: My '69 c-10
looks good... I just ordered some parts for my truck as well for the 5 1/2" front and 7" rear drop. Im 4 1/2" front and 5" rear now, needed MOAR Low...
Love your truck man...
Eric (Evaded)
If I see a Zombie.. Im runnin it over with my Truck.
Evaded is offline   Reply With Quote
Old 11-05-2013, 09:57 PM   #11
Keating121
Keating121's Avatar
Re: My '69 c-10
Originally Posted by bsteele View Post
Here is a picture of my c-10 after I dropped it another 2". Total drop now is about 5 in the front and 7 in the rear. I think I am going to go another inch in the rear.Attachment 1171163
Attachment 1171164
Love your stance bsteele. I think your slight rake is perfect. Researching what drop I should go with on my 67. What size wheels and tires are you running right now?
8/24/13 First Classic Truck
'67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny.
Keating121 is offline   Reply With Quote
Old 11-05-2013, 10:00 PM   #12
Ole Greenie
Re: My '69 c-10
New weekend project....Cut down the bump stops. Not interested in giving someone my $ for "alternative" stops...just yet. So a sawzall and some good lines...all leading to more clearance. I got it...bump stops are almost 44 years old...are they even rubber anymore! LOL!!
Evaded...Love SA! Been to FSH so many times I can't even count! Excellent town with a lot of attitude! SO many Army folks I know live there.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 11-05-2013, 10:06 PM   #13
Keating121
Keating121's Avatar
Re: My '69 c-10
Gorgeous truck Ole Greenie!! In my research I've heard of others cutting down the stops. Those small stops that ksshane mentioned sounds like the way to go! What method did you use to lower your's? How low is your tire's profile?
And Thank You for serving our Great Country and protecting our Freeedoms!!!!!
Old 11-05-2013, 10:20 PM   #14
bsteele
Re: My '69 c-10
Keating, I don't remember the tire sizes but rims are 20's. I will check tires tomorrow.
Old 11-05-2013, 10:24 PM   #15
Ole Greenie
Re: My '69 c-10
HOOAH!!!!!!
After being in the Army for these many years my Family and I are SO proud to still be serving this country! Thank you!
Appreciate your comments as I have been saving, working and drudging through it all for a while now. My wife calls the CST my "Mistress." Lol!
Anyway, I'll cut them down a bit at a time this weekend. I'd just like more clearance over all the bumps I encounter. It is a nice truck but I do drive it often...because I like it.
My drop is:
FT 2.5" springs AND 1" drop spindles. I didn't want too much trim for the upper control arms. Rims are 8X8 with 255/45/18 tires.
Rear: 4" drop springs. Rims are 8X9.5 with 275/40/18 tires.
I like a little rake in it from front to rear...Ole Skool
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 11-05-2013, 10:27 PM   #16
Ole Greenie
Re: My '69 c-10
Bsteele...your ride is sweet. Looks like it's unmolested and a solid "Southern Truck!"
Good luck on your C-Notch!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 11-05-2013, 10:29 PM   #17
Ole Greenie
Re: My '69 c-10
Attachment 1171164
Sweet!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 11-05-2013, 11:45 PM   #18
Keating121
Keating121's Avatar
Re: My '69 c-10
Thanks! That would be awesome!! I'm really working on trying figure out how much drop to give me a relation between tire height and truck drop that suits my eye.
Old 11-06-2013, 12:07 AM   #19
Keating121
Keating121's Avatar
Re: My '69 c-10
HOOAH!!!!!!
My drop is:
I didn't serve myself, both my grandfathers did in WW2 and some friends were in Desert Storm and a close friend was stationed in Afghanistan for about a year in 2011/12. I can't thank you and your men enough!!!
Cutting them should work. Like I said, I've read other posts where its worked for them! If that doesn't work, you could go with 2" blocks and 2" drop springs for more suspension travel. That's my part of my plan...so far...
What do you mean "didn't want too much trim for the upper control arms?" I was thinking 2" to 2.5" drop spindles. You disagree with that?
I'm like you, A little rake=Awesome Stance!!
Old 11-06-2013, 06:57 PM   #20
bsteele
Re: My '69 c-10
Keating, fronts are 255/45/20 and the rears are 275/45/20. Rears are about an inch taller than the fronts.
Old 11-07-2013, 08:03 PM   #21
Keating121
Keating121's Avatar
Re: My '69 c-10
Thanks.
So what are you looking for with your stance? Truck closer to ground? Less space between the tires and wheel wells? Both? Just curious. Thanks
Old 11-07-2013, 09:06 PM   #22
davtay68
davtay68's Avatar
Re: My '69 c-10
Ole Greenie. What brand did you go with for your drop? I have to fix the previous owners drop so I trying to get that figured out.
davtay68 is offline   Reply With Quote
Old 11-07-2013, 09:08 PM   #23
bsteele
Re: My '69 c-10
I little of both. My brother has a '65 on air ride with all porterbilt stuff on it. It will lay frame with 20's. Mine looks like a 4 wheel drive beside his.
Old 11-07-2013, 09:15 PM   #24
bsteele
Re: My '69 c-10
Here is a pic of my truck before I lowered it any and a pic of my brother's truck. It is the only one I can find on my computer.Name:  025.jpg
Old 11-07-2013, 10:54 PM   #25
Keating121
Keating121's Avatar
Re: My '69 c-10
Dude, is that your truck right now with a 5/7 drop???
