Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 12-03-2013, 11:17 PM   #1
blazerboy72
5.3, exhaust manifolds, cams, etc
01 5.3 36k miles $800
Comp big mutha thumpr $250
EPS 247/ 254 .623 113 lsa $250
Truck manifolds believe I have 2 sets $50 ea
GTO manifolds $75
05-07 lq4 shortblock cracked block $200
Truck intakes $50
blazerboy72 is offline   Reply With Quote
Old 12-05-2013, 09:45 AM   #2
68Stepbed
68Stepbed's Avatar
Re: 5.3, exhaust manifolds, cams, etc
Do the truck intakes have throttle bodies and injectors with them?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-05-2013, 11:20 AM   #3
blazerboy72
They don't but I should be able to find some. In know have dbw throttle bodies.
Old 12-05-2013, 09:07 PM   #4
68Stepbed
68Stepbed's Avatar
Ok. If/when I make the swap to EFI, I'll stick with DBC. I just spent the money for a new Lokar pedal setup and really don't want to have to spend more on an e-pedal.
Matt
Old 01-08-2014, 05:17 PM   #5
nitrusmike
do you have the part number on the Comp cam?
nitrusmike is offline   Reply With Quote
Old 01-28-2014, 07:49 PM   #6
454_72_4X4
454_72_4X4's Avatar
If you still have 'em, can you post pics of the GTO manifolds?
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
