Old 12-06-2013, 01:11 AM   #1
1972GMCsierra4x4
Heater Emergency!!!
So temps finally dropped off to winter here in Kansas and my heater still may as we'll be an air conditioner. Swapped cores, put in all new heater gaskets and nothing has helped even after I let my truck idle and warm up for 10 minutes. Any advice/help would be greatly appreciated
1972GMCsierra4x4 is offline   Reply With Quote
Old 12-06-2013, 08:26 AM   #2
cdowns
cdowns's Avatar
Re: Heater Emergency!!!
a 190 radiator thermostat and good antifreeze
Old 12-06-2013, 09:27 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Have you put your hands on the heater hoses to see that they are warm and that the coolant is circulating in there? Is the heater valve opening and closing? And, of course, youve got the radiator topped off and full, right?
That thing should toast you right out of there.
Tom Vogel is offline   Reply With Quote
Old 12-06-2013, 09:36 AM   #4
Longhorn 70
Longhorn 70's Avatar
I'd check the heater valve. BEWARE there are 2 types that look similar. One that opens on vacuum and one that closes on vacuum. I think we want the close on vacuum type.
As Tom said check the heater hoses. Make sure BOTH of them get hot.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-06-2013, 09:46 AM   #5
1972GMCsierra4x4
How hot are we talking? Both get pretty warm after the truck runs a little
Old 12-06-2013, 10:06 AM   #6
1972GMCsierra4x4
Hoses, that is
Old 12-06-2013, 10:06 AM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Heater Emergency!!!
Check the cables on the dash unit. Make sure they operate the door for the hot air. Just because they slide back and forth doesn't mean anything. U have to watch and see them working.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-06-2013, 10:09 AM   #8
Lee H
Lee H's Avatar
My heater will not blow hot air after just idling. It takes being driven a few miles and then it heats up slowly. After 3-4 miles it's really hot.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-06-2013, 10:44 AM   #9
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
I would say also check to see if the flapper door inside the heater box is open to let the heat from the heater core to blow out.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 12-06-2013, 10:46 AM   #10
463
463's Avatar
You will have to have a system pressure test to see if there is a leak. in most cases you rad cap is weak. Systems need 15 - 16 lbs psi to work right when it's cold. Start by replacing the rad cap first.
Trueman
463 is offline   Reply With Quote
Old 12-06-2013, 11:37 AM   #11
1972GMCsierra4x4
Thanks for all of the help guys, I really appreciate it. As it turns out, my radiator wasn't completely full. I topped it off before I went to class this morning and I'm going to burp my coolant system during shop today to get all of the air out (just in case). I'm not sure if my blend door is working right, but I think it is because when I move the lever, the air flow through my floor vent changes. I'll make sure it is when I replace my in-cab gaskets either tonight or this weekend. As for y'all who said to check my heater valves, I forgot to mention that the one of the POs by-passed them and installed straight hoses.
Old 12-06-2013, 02:01 PM   #12
1972GMCsierra4x4
One more question. How do you guys have your heater hoses routed? I've got the one from my water pump going to the inlet of my core at the bottom and the top return line going to the radiator. Is this right or wrong? The PO had them routed this way so that's how I did them.
Old 12-06-2013, 02:09 PM   #13
Lee H
Lee H's Avatar
OK, that's why you have little heat. A better routing is intake to bottom of heater core, top of heater core to radiator or water pump.
Old 12-07-2013, 01:24 AM   #14
1972GMCsierra4x4
Glad to say that my heater works awesome now! Thanks to all who gave advice!
1972, gmc, heater
