Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-18-2013, 09:33 PM   #1
duckdude
speaker solutions
what have you guys done for speakers in your trucks if you have left your gas tank in cab and don't want to cut your doors? I would like to use a pair of 6x9 but cant figure where to put them
duckdude is offline   Reply With Quote
Old 12-19-2013, 03:18 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: speaker solutions
I built a center console to hold my amp and some 6.5" components, but that requires bucket seats.
If you don't want to cut the doors, keep bench seat, keep tank, and fit speakers, you'll be limited. You can try to modify something in fit in-dash where the mono speaker would go, or get kickpanels. And if you are only putting 1 pair of speakers in the truck to help with sound, then DON'T get 6x9's. There are much better sizes of speaker for delivering good sound with less distortion, and will take up less room. 4.5's, 5.25's and 6.5's all come to mind.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-20-2013, 03:39 PM   #3
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
In my old '68 I built a small boxes for 6x9 and just fit under the seat.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 12-20-2013, 08:59 PM   #4
duckdude
texasjeff do u have any pics of them
Old 12-21-2013, 09:00 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: speaker solutions
I bought these a couple of weeks ago. 'member bigblock73' Plan to install them. You would have to cut the top out of the drivers side panel for the gas neck but they should work with some moding.
I was going to put 6x9 and some mids in the panel but I think just a good set of 6x9's will be the ticket.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-22-2013, 08:30 AM   #6
duckdude
has anyone made a box to sit at the base of your seat?
Old 12-26-2013, 09:29 PM   #7
MashTheGas 72
I was looking into one of the woofer/Amp setups that will fit under our seats. I haven't made a decision on name brand to go with.
72 GMC 1/2 Ton
MashTheGas 72 is offline   Reply With Quote
Old 12-28-2013, 08:54 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Years ago, I put a set of 6X9 speakers in the lower door panels on my 72 Chevy C-10 and then just above the gas tank, there IS room enough for a set of 6" round speakers in the metal valance under the rear window. They will have to be a pretty shallow fit though. In this day and age, you could fit a later model set of 4" square speakers in the rear pillar or in the valance behind the seat.
Frank
piecesparts is offline   Reply With Quote
Old 12-30-2013, 11:58 PM   #9
rpatowers
I installed four speakers: Two via kick panels and two under seat speakers. The under seat speakers I hung upside down under my bucket seats, because if I mounted the driver's side speaker on the floor the it would interfere with the seat adjustments.
It all sounds OK. I also put a lot of sound proofing material in my truck.
rpatowers is offline   Reply With Quote
Old 12-31-2013, 12:16 AM   #10
slowcpe
slowcpe's Avatar
If my doors weren't already cut for 6x9s (which I really dislike), I would personally put 6.5 components in a kick panel mount. Since I already have the holes, I'm looking to fill them with Fosgate P1694s and (2) P142s in the dash location.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-01-2014, 09:41 PM   #11
Billett
Billett's Avatar
Take a look at some other threads in the audio section. I know there are pictures to what you're looking for in at least three recent ones. I replaced the center mono speaker with two 4" speakers, put two 6.5s under the seat and right now I'm looking into an RF shallow mount. There's a lot more room under the seats than people think. Won't be super high quality sound because sound coming from under the seat isn't really ideal, but with the amount of wind noise these things make its not going to be particularly clear anyway.
Same sort of thing goes for 6x9s in my opinion. They are more loud than clear, but unless you are an SQL type guy, the average joe won't care and would be happier with the increased volume.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 01-13-2014, 06:38 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
stock,mono 1 speaker now
front, cheap and stockish
back, this is a Jimmy I replaced the ashtrays with speakers
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-07-2014, 12:26 PM   #13
bigmac73
bigmac73's Avatar
here is what i did , found a guy that works in a local woodworking hobby shop build this for me on as a side job , cost me around 60 bucks
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 05-16-2014, 12:40 AM   #14
K10 STEPSIDE
K10 STEPSIDE's Avatar
there is room to fit fairly large speakers under the dash pointed down I have a 6.5 in each corner and could fit larger, i just had to make a small bracket to hold them. sorry no pictures.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 05-16-2014, 12:46 PM   #15
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
i woner if this would fit 60-66
Sick5 is offline   Reply With Quote
Old 07-20-2014, 12:23 AM   #16
Boyd
Resident Lurker
Boyd's Avatar
This is what I did. I removed my in cab tank, but this would work with an in cab tank...
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken
Boyd is offline   Reply With Quote
Old 07-20-2014, 04:48 PM   #17
Andy4639
Old member
Andy4639's Avatar
Wink Re: speaker solutions
I think he sales them for differant models but I'm sure you could trim them to fit.
