Old 12-31-2013, 08:44 PM   #1
hellbent72
Re-7 vs Re-8 switch for ride quality at set ride height
My truck now has slam Re-7s all around I'm running 80psi front and 35psi rear for a 5inch ride height and find myself running 70psi front and 30psi for the best ride but puts me at a 4 inch ride height.
Would switching to the re-8s allow me to run less bag pressure for a smoother ride at 5 inch ride height over the smaller bag
hellbent72 is offline   Reply With Quote
Old 01-01-2014, 12:53 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Re-7 vs Re-8 switch for ride quality at set ride height
If being able to go as low as possible when deflated is less important than ride quality I would recommend keeping the 7s and making a spacer to go under the bag. 1/2" spacer under the bag should give you an inch at the spindle. That should be the quickest/easiest/most economical solution.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
