Old 01-01-2014, 02:18 PM   #1
danheit
danheit's Avatar
where to buy air line and fittings
Hey guys, just about have everything pieced together for my rear air ride setup. Dominator 2600 Bags are currently in place (gonna see how they ride before I buy front bags, maybe swap out for 2500's), I just picked up 8 SMC 38" valves (used but in good shape - $50!) and the valves came with a good bit of the fittings I will need to put everything together. Also picked up a vintage air pressure gauge on ebay for $5 from a 1940 GMC Bus. All I have left to do is run the wiring, mount my tank (old fire dept SCBT) and run the air line. I am looking to go with 1/2" line since that's what most of my fittings are for, and am trying to find out where the best (read CHEAPEST) place to get decent line by the foot. I am looking for just some plain black DOT 1/2" Nylon line, about 25' of it. I have seen pricing all over the place, and have found it as cheap as .58 per linear foot, but $12 worth of line was $12 for shipping. I might also need a fitting or two to get everything finished off, but nothing I can't work around locally. Where are you guys getting your line? Is there a difference between the Airbagit line vs. other? Vendors, please feel free to chime in here too! Thanks!!
1955 Chevy 3100 Task Force Pro Street - Sold!
1957 Chevy 3100 Task Force "Rat Rod" a.k.a. SLOTH - Sold!
1971 C10 Longbed factory A/C all stock 350/350
1979 Jeep CJ7 - Build date on the day I was born! -Keeper
2004 Expedition - Family Hauler
2007 Accord - Wife's around towner; I have more but not enough lines to post them!
danheit is offline   Reply With Quote
Old 01-01-2014, 02:44 PM   #2
mongoose
mongoose's Avatar
Re: where to buy air line and fittings
i got a couple fittings and some air line from a local truck shop.. cheap enough for being local and having it now.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-01-2014, 02:47 PM   #3
Pro Performance
Pro Performance's Avatar
We don't have line that is $0.58 per ft., but we sell 1/2" DOT line, which we feel is a good line to run vs. other non DOT line. A 25 ft. roll runs $25 plus $15 to ship. Not the cheapest line you can buy, but it's quality, which is what you want for air suspension when it will be essentially what is holding up your truck.
http://www.azproperformance.com/1-2-...-Air-Line.html
Pro Performance is offline   Reply With Quote
Old 01-01-2014, 05:53 PM   #4
broey
Square
broey's Avatar
yeah, price shouldnt be the deciding factor when purchasing air ride equipment. az pro performance is going to have what you need.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 01-01-2014, 11:01 PM   #5
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Pro Performance will def have whatever you need. We needed something FAST so we went to a local Peterbuilt dealership and they had everything we needed.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 01-02-2014, 11:58 AM   #6
danheit
danheit's Avatar
OK, now another question, I have seen two different types of fittings, one that is all brass (Push to Connect, of course) and the black plastic upper with a brass lower. Suggestions?
Old 01-02-2014, 06:49 PM   #7
Pro Performance
I prefer the all brass construction, so there is no plastic to accidentally break. The all brass style is all we carry, because they work so well and seal up nicely without issues. When using PTC, always make sure to re-cut your line if every time you remove it from the fittings. Also, make sure it is a very straight cut.
Old 01-03-2014, 11:32 AM   #8
danheit
danheit's Avatar
Thanks for the info! I am curious though, have you ever had issues with the 90 elbow brass fittings cracking at the bend? I have read that a few places, and if I am going to do this, I would like to only do it once!
Old 01-03-2014, 01:26 PM   #9
Pro Performance
I have never had an issues with the elbows breaking. Using a good sealant, like Loctite 545, the fittings should not take a lot of torque to seal.
