01-03-2014, 12:50 AM | #1 |
Idler Arm separation tricks?
Ok, I give!
What is the trick to separating the Idler arm from the Drag link? I've been pickle-forking like Rocky Balboa on a Side of Beef but no luck! The pitman side came off with not too much hassle. I even tried a little heat, but the but the rubber started smoking pretty bad. How did you do it? Heat?? I'm tempted to take the whole drag link off and but it in a vise where I can get proper swings at it. Working upside side is not that much fun! Thanks! Nick |
01-03-2014, 12:57 AM | #2 |
Robert Olson Transport
Re: Idler Arm separation tricks?
I generally just whack it good with a baby sledge and it falls apart
01-03-2014, 02:19 AM | #3 |
It sucks, I just did this when I replaced all my suspension and steering components. I used a small sledge right after I heated it real good. Just kept working at it. It took about an hour before I realized I needed the bigger hammer and a torch for heat. I replaced everything so if it burned some rubber that was fine with me. Keep working the fork around. Maybe you will find the sweet spot.
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that! I like long walks on the beach, dinner by candle light, and poking dead things with a stick. |
01-03-2014, 02:28 AM | #4 |
I have had luck using an air hammer and right size fork, also.
Les |
01-03-2014, 04:13 PM | #5 |
So what worked was taking the outer tie rods off, then bringing the whole assembly down.
Meaning the "drag link" with the inner tie rods attached & the Idler arm also. Once on the ground I could get a proper Hammer Whack at the nut side of everything and it just popped off no problem! BAM! Enjoy! :-) |
01-03-2014, 06:06 PM | #6 |
heat evenly, then apply the big hammer... liberally
01-04-2014, 07:32 AM | #7 |
I just took one off a 82 last night. I used the air hammer with the pickle fork attachment. I believe it was the original with almost 300K miles on it. Chip.
