Old 01-18-2014, 08:09 PM   #1
'68 Short Step
'68 Short Step's Avatar
transmission mount
I am finishing up my th350 to 700r4 swap and I ran into one last snag. The 700r4 transmission mount is too tall. I tried to jack up the trans to mount the cross member but even with the trans touching the bottom of the cab the rubber on the transmission mount is too thick to slide the crossmember under it.
Does anyone know of a more slim or low profile transmission mount I could use? I need about an inch. Thank you all
'68 Short Step is offline   Reply With Quote
Old 01-18-2014, 11:36 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: transmission mount
Just reuse your TH350 mount. It's the same bolt pattern as the 700 uses.
Old 01-19-2014, 12:26 AM   #3
'68 Short Step
I already sold the trans.
Old 01-19-2014, 02:22 AM   #4
Z10
Z10's Avatar
Let me see if I can find where I bought mine. I just did this swap and didn't have any issues. Didn't even have to drill holes for the crossmember.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-19-2014, 07:53 AM   #5
Tx Firefighter
Anchor part number 2268.
$ 5.69 at O Reilly Auto Parts
Old 01-19-2014, 12:39 PM   #6
'68 Short Step
Ill have to swing by oreillys and take a look at that one. I ordered one from cpp that looks like that but its the one that's too thick.
Old 01-19-2014, 02:24 PM   #7
Tx Firefighter
Assuming you're using a stock 67-72 type of automatic trans crossmember and a mount like I posted above, if its still hitting, you might look toward sagging cab mounts. That is a combination that has been done many times by many people, including myself personally. It should work without hitting.
