Old 02-01-2014, 02:19 PM   #1
jmader
jmader's Avatar
1967 GMC 4X4 Long Box Build
So I've finally decided to make a build page. I've been working on this truck since last October and have taken a few pictures along the way so I'll post what I have now and update them as I go. The truck itself is one of the first 67's to roll off the assembly line. The serial # is in the teens. It is also a factory V8 (VIN KE1590DXXXXXXX) which almost all of the 67 4X4's were the V6 version. I have an original 67 GMC sales brochure that doesn't even list a V8 as an option. The original engine was long gone so it took me a while to find a block correct for the truck. I ended up finding a 327 after a very long search and it it being machined right now. So I guess now I'll just start posting the few pictures I have and go from there.
This is what I started with.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 02-01-2014, 02:25 PM   #2
jmader
jmader's Avatar
Re: 1967 GMC 4X4 Long Box Build
Interior
1967 Chevy SWB K10
Build thread-
Old 02-01-2014, 02:39 PM   #3
jmader
jmader's Avatar
Here's a picture after I had the frame sandblasted. The aqua truck in the background is where I'm getting the grille, fenders, and box from. I ended up pulling the axles and changed all the bearings and seals in the differential and axle shafts as well as the front axle U-Joints and hub bearings. Someone took out the manual lockouts at one point as slugged them so they were full time 4X4 and not in very good shape. I also took apart all the leaf springs and painted both sides and painted the chassis satin black with KBS Paints chassis coater. The paint looks pretty dull because it got sprinkled on the day after I painted it outside then started collecting dust on it. The next couple pictures show the front end after I reassembled it.
1967 Chevy SWB K10
Build thread-
Old 02-01-2014, 02:44 PM   #4
jmader
jmader's Avatar
Here's a couple more of the frame and parts ready for paint.
1967 Chevy SWB K10
Build thread-
Old 02-01-2014, 02:50 PM   #5
jmader
jmader's Avatar
I didn't get any good before pictures of the cab but here's the progress I've made on the sheet metal work. I put in both front supports along with the entire rear support cross member. Them rear floor patches, kick panels, front pillars, inner and outer rockers, and cab corners. Took me about 2 weeks to do it all and the next one I think will be a full floor pan. Making all the cuts is a little too time consuming for me.
1967 Chevy SWB K10
Build thread-
Old 02-01-2014, 05:13 PM   #6
CanadianK10
Active Member
CanadianK10's Avatar
Great progress, trucks coming along nicely
-Adam
1967 K10 292, SM65 Transmission & NP205 Transfer Case
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=605048
CanadianK10 is offline   Reply With Quote
Old 02-01-2014, 11:40 PM   #7
thelonerife
thelonerife's Avatar
very nice truck. I like the 3/4 ton 4x4s.
thelonerife is offline   Reply With Quote
Old 03-06-2014, 02:54 PM   #8
jmader
jmader's Avatar
I haven't made a lot of progress lately but here's a couple pictures of my dash. I am adding A/C and decided to cut my dash rather than replace it with a factory air dash. I got an air dash thrown in with a bunch of parts I bought so I cut it up to use as a template.
1967 Chevy SWB K10
Build thread-
Old 03-06-2014, 03:00 PM   #9
jmader
jmader's Avatar
Got my buddy buckets stripped down to the frame. They're being powder coated next week along with the frame and about 50 other random parts both interior and engine compartment. Grille support, brackets, pulleys, etc.
1967 Chevy SWB K10
Build thread-
Old 03-06-2014, 03:05 PM   #10
jmader
jmader's Avatar
Took the cab to be sandblasted this morning. Taking it to start the body work tomorrow.
1967 Chevy SWB K10
Build thread-
Old 03-06-2014, 06:57 PM   #11
mx289
mx289's Avatar
Very cool truck.
Your off to a great start.Looks good.
Tom
mx289 is offline   Reply With Quote
Old 04-18-2014, 05:04 PM   #12
jmader
jmader's Avatar
Not much progress lately since I farm for a living and I've been putting in a lot of hours working lately. I did tear the wood floor out of the box and had the cross rails sandblasted. I primed and under coated them yesterday and will get pics of that.
1967 Chevy SWB K10
Build thread-
Old 04-18-2014, 05:06 PM   #13
jmader
jmader's Avatar
Also got the 327 back from the machine shop. Got the bottom end put together this morning. Hopefully get the top end put together this weekend so I can get it painted and set back on the frame.
1967 Chevy SWB K10
Build thread-
Old 04-18-2014, 06:45 PM   #14
Maxxd07
Maxxd07's Avatar
Very nice! Sounds like you found a diamond in the rough.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 04-23-2014, 03:39 AM   #15
brianb41
brianb41's Avatar
I was checking out your restoration it looks like youve done agreat job i have a question for you if you dont mind i am currently doing same thing to a 72 k10 swb i noticed the panels you replaced on floor that the rocker panels marry up to at the weather stripping mine is rusted through there too iv got the inner and outer rocker panels and cab corners already but didnt realize that the floor was in need of repair untill last weekend i was afraid that i would have to buy complete floor pan and cut it up for those panels i was wondering if they sell those panels like u have or how did u get them? I have LMC and RayBuck books but not sure which piece in the books that i need or if their even in there i am inexperienced in all this since this is first build and their seems to be cpl panels that might be what i need i just dont know what they call the pieces im looking for and want to make sure i get the right pieces can u help me identify the edges of floor pan with correct name or part number? Or do i have to cut them out of complete floor pan? Of corse i want to avoid that if possible since panel is 400 bucks with 125:doller shipping fee any help would be greatly appreciated user name is brianb41 thanks
brianb41 is offline   Reply With Quote
Old 04-23-2014, 10:20 AM   #16
jmader
jmader's Avatar
I believe what you're looking for is item #6 in this picture. It would be part # 38-7904 and 38-7905.
1967 Chevy SWB K10
Build thread-
Old 04-23-2014, 10:20 AM   #17
jmader
jmader's Avatar
Whoops forgot to add the picture.
1967 Chevy SWB K10
Build thread-
Old 04-23-2014, 11:44 AM   #18
brianb41
brianb41's Avatar
Thanks for the reply you are right that is the piece i need and at alot better price then complete floor i see now that there is a full and a partial panel im not sure which one i need but found tbe full piece on sale for 49 bucks each so to be safe ill go that route i appreate you taking the time to clear that up for me ill.be relieved when all the sheet metal work is done i find it a little intimaidating with no experience in it and am eager to continue the project im glad i found this site with all you experienced guys im sure ill be asking alot more questions and learning alot from it thanks again
Old 04-30-2014, 12:12 PM   #19
530FF
Project is moving along and looking great Jeremy , which vendor did you get your spring and shackle bushings. Read some members had fitting issues with some vendors. Getting ready to replace mine on a 68 being the same wide springs of a 67.
Thanks for the help Richard
530FF is offline   Reply With Quote
Old 04-30-2014, 01:25 PM   #20
mcbassin
Still Learning
mcbassin's Avatar
Looks like a very good start to a restoration project. I'm going to follow along too.
mcbassin is offline   Reply With Quote
Old 04-30-2014, 02:02 PM   #21
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
You are doing a great job, Looking forward to seeing your progress.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 05-04-2014, 12:18 PM   #22
jmader
jmader's Avatar
I bought them from LMC before I knew any better. They're ok but a couple of them didn't fit as tight as I would like them to. I know Brothers sells them and possibly Classic Industries which would both be closer to you. I used the rubber bushings so I have no real insights on the polyurethane ones.
1967 Chevy SWB K10
Build thread-
Old 05-04-2014, 02:28 PM   #23
530FF
Thanks for the reply and recommendation Jeremy , will try Brothers and stay with the rubber bushings, looking forward to progress on your truck Richard
Old 05-14-2014, 03:35 PM   #24
jmader
jmader's Avatar
Finally got the engine set back on the frame.
1967 Chevy SWB K10
Build thread-
Old 05-14-2014, 03:37 PM   #25
jmader
jmader's Avatar
And the tranny and transfer case. This was a LOT harder that I was expecting. Took me about 3 hours to get it lined up right but I'm glad it's finally done!
1967 Chevy SWB K10
Build thread-
