Old 02-02-2014, 05:01 PM   #1
Culchie
Mileage question
Probably a stupid question, but, I have a 1978 K10 with a 1992 350cid, 700r4 trans, np241c, Rochester 4bbl (just rebuilt) just tuned up and oil change. I'm running 33's but not sure of the gearing. my question is, I'm getting about 3-5 mpg city! is this normal??? (it may also have a mild cam)
Culchie is offline   Reply With Quote
Old 02-02-2014, 05:22 PM   #2
meatwagon83
meatwagon83's Avatar
Re: Mileage question
should be getting better than that!!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 02-02-2014, 05:25 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
You got a few unknown variables to your mileage equation. Gearing? Is the speedo/odometer accurate? Without accurate mileage, you can't correctly calculate your MPG's. Given that you have a 241 and 700r4 swapped into a 78 it may not have the correct speedo gear for your combination.
So to answer your question, 3-5 mpg city does seem low. But not far from what might be going on. 33" tires with highway gears causes more effort to be made to get rolling, that equals more fuel being used to get up to speed. You need to fill in the blanks to get an accurate mileage reading.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-02-2014, 05:59 PM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
use a GPS to determ'n if your speedometer is correct and go from there, my call is the speedo is way off.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
1978 k10, 33", carburetor, mileage
