Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 02-13-2014, 03:01 PM   #1
rockin rebel
1949 gmc, rear, cab mount.. NOT chev
This is a first for me.. all old Chevy trucks have the shackle on ea. side.. but I have a US ..GMC and it is not the same and I can not see, how it comes apart... help anyone.??? thanks, Lloyd
rockin rebel is offline   Reply With Quote
Old 02-13-2014, 05:08 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1949 gmc, rear, cab mount.. NOT chev
The 47-48 and some 49 Chevy and GMC had a center mount and its a PIA to get at . You need to do it from under the truck.
http://chevy.oldcarmanualproject.com...47ctsm0102.htm
dwcsr is offline   Reply With Quote
Old 02-13-2014, 07:21 PM   #3
rockin rebel
thanks found that pia bolt...
Old 03-28-2014, 06:28 PM   #4
Gippetto
I rebuiilt the center shackle on my '47 GMC and the kit from
Classic Parts was good except the new rubber bumpers that the cab corners sit on were round instead of rectanglular and were also 1/4" higher than originals. I used them as is thinking the old ones may have been worn or taken a set. The shackle went back in but needed a 1/4" spacer to bolt up with no strain on it. When I did the front cab mounts I spaced the front up 1/4" to keep the same attitude. I will also have to add 1/4" under the radiator frame to lift the fenders as well.
If you buy a shackle rebuild kit let us know how it goes.
Also, could you post a picture or two of the sheet metal that house the center shackle. Mine is so shot and hatcheted that I need something to go by to close it back up.
Gippetto is offline   Reply With Quote
