Old 02-18-2014, 01:46 AM   #1
azer
question about grinding/roar noise
Picked up a 78 Chevy c20 automatic 350 2wd there is a grinding/roar noise coming from driver side floor board, if I put my food on the floor board under the brake pedal I can feel a vibration it feels like metal to metal grinding. It gets louder with speed anything above 40 it's extremely loud making sharp turns doest seem to effect the sound. I coasted down a hill with the Engine off and transmission in neutral the sound was still there even at very low speeds I can hear it (5 - 10) mph. also if the truck has been sitting for awhile like overnight the noise doesn't seem to start until driving for about 3 or 4 minutes.
Im new here any ideas very appreciated !
Thanks!
azer is offline   Reply With Quote
Old 02-18-2014, 02:17 AM   #2
jhngardner367
jhngardner367's Avatar
Re: question about grinding/roar noise
Welcome to the forum !
I think you should check your drive shaft for bad cross joints. It sounds like one(or more) is worn.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 02-18-2014, 12:13 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Welcome
If it's not the front brake squealers or dust shields I'd vote Ujoints,
sometimes they will "ping" going into R/D
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-19-2014, 03:27 AM   #4
azer
Spent most the day messing with it and I believe very much so the noise is coming from the transmission. There is a little bit of play in the shifter while driving i wiggled the shifter around and pushed it in the upwards position just a hair and the noise almost completely went away let off the shifter back into its resting position the noise instantly came back. Then i pushed the shifter down a little and the noise got extremely louder. Now im real confused of what it could be something in the shifter linkage or something more serious inside the transmission
Old 02-19-2014, 08:28 AM   #5
jhngardner367
It sounds as if the trans may have a bad output shaft bearing,or input shaft bearing.
I would drain the trans,and check for metal in the pan/filter.
c20, grinding
