Old 02-18-2014, 09:21 AM   #1
ole_66
Rims & Tires on a Lowered '66
I am neck deep into my '66 Chevy Fleetside/Longbox overhaul. So far I've done a fuel tank relocation, all new lines, electric pump, filter, AN conversion, Weiand intake, Holley Carb, carb spacer for the fuel system on a mildly built 383. I found an awesome aluminum radiator/shroud/electric fan combo from a company in Cali and redid the cooling system. Reconditioned the existing electrical system and added a new/separate circuit for all the new electronics.
Phase two is a disc brake conversion, Auburn locker, 2.5 inch front/3 inch rear drop, a 5x5 lug conversion, and general suspension upgrade.
I am looking at rims and tires now, and have found a set I like, my question is, will 18x9s and 20x10s fit under my Chevy? Does anyone have any experience with this or advice?
Ole
ole_66 is offline   Reply With Quote
Old 02-18-2014, 09:39 AM   #2
kieth
kieth's Avatar
Re: Rims & Tires on a Lowered '66
You will have to modify the rear wheel tubs to get the 18 x 10's to fit the rear. I am running 17x9's and here is the problem with them.....
go here post #2 for some photos......Kieth
http://67-72chevytrucks.com/vboard/s...d.php?t=616962
kieth is offline   Reply With Quote
1966 c10, 1966 chevy c10, rims size, rims wheels, wheels tires
