Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 03-01-2014, 02:36 PM   #1
tranzamwayno
is this a 46 shortbed frame? i need pics or specs to verify
found this frame suppose to be 46 chevy shortbed, can anyone confirm what it is? heres pics and measurements if anyone knows what i got.
total length 173 3/4"
total diagonal length 176 3/4" its square
front side to side (minus horns) 24 7/8"
front at 1.5" holes 25 7/8"
center of rear wheel opening 43 1/2"
at rear crossmember 46 1/8"
rear 46 1/4"
i read front is suppose to be 25 5/8" and rear 44 1/4"
front to center of hanger 35 1/4", rear crossmember to hanger 52 1/4"
there are no spring hangers on this frame
tranzamwayno is offline   Reply With Quote
Old 03-02-2014, 01:13 PM   #2
paintman
Re: is this a 46 shortbed frame? i need pics or specs to verify
Not sure but to me something looks a little different than mine. I had a different trans cross member. Here's a pic of my 46.
here's a pic of the my 46 frame after I stripped out the Pacer front end the PO boggered into it.
paintman is offline   Reply With Quote
Old 03-02-2014, 09:36 PM   #3
wingedexpress
wingedexpress's Avatar
looks like a late 47 and up advance design frame.
wingedexpress is offline   Reply With Quote
Old 03-03-2014, 06:21 PM   #4
tranzamwayno
only good pics i found were on ebay and my frame does seem to be the 47-53 a/d design. im going to do some measuring and see what it will take to use with my 41 cab. i have not found any info about putting the art deco truck on the advance design frame.
Old 03-08-2014, 04:01 PM   #5
tranzamwayno
after measuring it looks like everything will bolt to the frame except the rear body mount (frame is 1" too wide). wheelbase is within an inch so thats good.
im going to get the interior mocked up and a front ifs ready before i set the tub and front on the frame. so it will be a while
Old 03-08-2014, 05:13 PM   #6
wingedexpress
I did a 45 body on a 52 1 1/2 ton frame the only big issue i had was making bumper brackets. The frame was a little wider at front, a 1/2ton frame may not be a problem or if your not going to have a stock bumper.
