Old 03-08-2014, 05:02 AM   #1
mijotter
Exclamation Chevy Pickup Towing Information
Greetings. I own a 1994 Chevy 1500. V6 4.3L 2WD Regular cab, 8ft bed.
I'm curious what the tow rating is and the GCWR.
I checked the door and I got this:
GAWR RR = 3404
GAWR FT = 3150
GVWR = 5600
I'm guessing the GVWR is the curb weight of the vehicle plus what it should have on the truck itself such as cargo and persons am I correct? IF it is then the payload for the bed can't be much since the curb weight of the truck is roughly 4100lbs.
I'm planning on getting a trailer for a boat but need to know how much this truck can handle before I go out and purchase what I'm towing.
Thank you.
mijotter is offline   Reply With Quote
Old 03-08-2014, 09:19 AM   #2
95K1500
Re: Chevy Pickup Towing Information
Here is a link to the origional Chevy brochure for a 1995. Im guessing the tow rating would be the same or at least close for other years. The brochure is for a Canadian truck but it is still usefell and neat to look at. See the links below.
Towing Info
http://www.lov2xlr8.no/brochures/che.../bilder/20.jpg
The whole brochure
http://www.lov2xlr8.no/brochures/chevy/95ch/95ch.html
95K1500 is offline   Reply With Quote
Old 03-08-2014, 04:42 PM   #3
mijotter
Wow thank you so much.
The manual says a 7 pin harness is included on all models. Would that be true for the 94 model as well? If so, how do I check for it?
Old 03-09-2014, 02:21 PM   #4
95K1500
My 95 was already wired for a trailer when I bought it so I'm not sure how it was wired. But I did the trailer wiring on my dads 2000 Silverado and it had a pigtail of trailer wires all labeled. It was tucked up with the other wiring close to the spare tire.
I would crawl up under the back of the truck and see if there are any wires not hooked up to something.
gcwr, tow, towing, truck, weight
