Old 03-16-2014, 12:13 AM   #1
Russ.W.
Russ.W.'s Avatar
Question 1967 Upper control-arm/a-arm mounting bracket
I'm trying to find a few parts for my 67 C10, but I need the forum knowledge-base to chime in if possible.
One part I'm after is the L shaped mounting bracket that mounts to the frame, that the upper control-arm/a-arm shaft mounts to.
What I need to know is a) are these the same from 67-72? and b) are there differences between 2wd, 4wd, etc?
This is a part I have to buy used (LMC make the 73+ version, but not this), and will be placing a wanted ad on the forum, so I need to make sure they come form the correct vehicle before doing so
Here's some pics for those unsure what I'm referring to:
The piece circled:
Thanks for your time.
Cheers,
Russ
Old 03-16-2014, 12:21 AM   #2
Drewski23
Re: 1967 Upper control-arm/a-arm mounting bracket
junkyard or find someone parting out a truck would be your best bet. Post on the classifieds here looking for it
Drewski23 is offline   Reply With Quote
a-arm, bracket, control arm, mounting
