Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-21-2014, 02:57 PM   #1
Dorkfish52
Dorkfish52's Avatar
Camper special shortened and converted to 4x4
Hi all, new to the forum, I'm doing my first frame shortening, first 67-72 chevy and first 4x4 conversion... First 4x4 I've owned actually... Thought if make a build thread and if any of you have any advice or tips I'd appreciate them!
I'm starting with a 69 2wd camper special
Dorkfish52 is offline   Reply With Quote
Old 03-21-2014, 03:02 PM   #2
Dorkfish52
Dorkfish52's Avatar
Re: Camper special shortened and converted to 4x4
I'll post some pics of what I've gotten done so far...
Old 03-21-2014, 03:07 PM   #3
Dorkfish52
Dorkfish52's Avatar
Pulled the bed
Old 03-21-2014, 03:11 PM   #4
Dorkfish52
Dorkfish52's Avatar
Already cut and welded frame
Old 03-21-2014, 03:14 PM   #5
Dorkfish52
Dorkfish52's Avatar
4x4 hangers and rear end out of what I was told was a 72 4x4
Old 03-21-2014, 03:32 PM   #6
Dorkfish52
Dorkfish52's Avatar
After
Old 03-21-2014, 11:25 PM   #7
swamp rat
swamp rat's Avatar
Be sure to add reinforcement plates to the inside of the frame, you did your frame differently than in this thread but i wanted you to scroll down and look at how they reinforced the inside of the channel.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-22-2014, 01:49 AM   #8
Dorkfish52
Dorkfish52's Avatar
I was planning on just boxing in the frame right there... Do you think the reinforcing plate will be better?
Old 03-22-2014, 10:10 PM   #9
Wrecked1982
Wrecked1982's Avatar
boxing the frame will reinforce only the Inside ,not the outside where you did the weld. imo its way better to weld a plate Inside the frame
Wrecked1982 is offline   Reply With Quote
Old 03-23-2014, 12:34 AM   #10
Dorkfish52
Dorkfish52's Avatar
Okay plate inside the frame... It shall be done! Thanks for the help!
Old 03-23-2014, 06:29 AM   #11
Dorkfish52
Dorkfish52's Avatar
Okay questions.... I'm going to pull the inner fenders and maybe the outter fenders then install front 4x4 gear... I'm using rear hangers from a 79, I know they aren't the same as 67-72... Should work though, my question is about the steering box, I have a 4x4 steering box but in other threads I've read that they don't match up bolt hole wise... What do I need to do? Also I'm going to put the trans in, got an auto trans and 203 case out of a 79 gmc, does the trans crossmember go in the same holes as a 2wd? Is it that easy? Or do I need to drill? And where should I drill... Also unsure about motor mounts... Do I need to just find 67-72 4x4 mounts? Or are there other options? Thanks for any help!
