Old 04-02-2014, 02:30 PM   #1
briscuba
briscuba's Avatar
70 C10 disc brake conversion help needed
Hi,
I have a stock 1970 CST/10 big block. Awesome motor, but heavy for braking! I need to put disc brakes on it.
I just picked up a front end clip from a "Heavy Half" 1995 blazer. I believe it is known as "Heavy Half" anyways, and does have the 6 lugs. The "A" arms look different, prob. won't work, but will the spindles and disc brakes?
Does anyone know if this clip can help me at all?
Thanks!
briscuba is offline   Reply With Quote
Old 04-02-2014, 03:44 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: 70 C10 disc brake conversion help needed
Probably not. After all of the machine work and custom parts it would be cheaper to buy a kit.
There's a faq section on disc brake swap questions showing the stuff that interchanges between 64-88
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-02-2014, 04:07 PM   #3
TwinsSpeedShop
Don't do it!! I used 88-98 spindles and there are alignment problems and after rebuilding all the parts that needed it, I wish I would have just bought the kit. You will brake even or come out ahead if you buy the kit and have far less headaches
TwinsSpeedShop is offline   Reply With Quote
Old 04-02-2014, 05:04 PM   #4
steelhorse
steelhorse's Avatar
If you want to use factory spindles you can use the 73-87 but they will take you to 5 lug. you will also need to use the ball joints and tie rod from they same years.
steelhorse is offline   Reply With Quote
Old 04-02-2014, 05:04 PM   #5
SS Tim
SS Tim's Avatar
http://67-72chevytrucks.com/vboard/s...68&postcount=4
SS Tim is offline   Reply With Quote
Old 04-02-2014, 08:13 PM   #6
hugger6933
You can use all gm stuff like the 6 lug rotors and spindles and the 68 lower control arms use the newer ball joints and tie rods and then the calipers and all of the stuff will work. But I have gathered all of these parts well just from not throwing junk away cause I have a 95 3/4 ton that I junked and had the whole front suspension. the problem is when you build the truck it all looks and fits together real good and everything gives you a warm and fuzzy feeling then when you get farther along on the project and get it on the road, take it to get a front end aliginment it can't be done it is too far out of spec to get close with shims. Nobody on here that I have heard of that has used this set up has been able to get the steering lined out that I know of, it may have happened while I was sleeping but I just think your better with some aftermarket of the shelf stuff.
hugger6933 is offline   Reply With Quote
Old 04-06-2014, 04:07 PM   #7
briscuba
briscuba's Avatar
Thanks guys, really pleases with your responses and this forum. No need to reinvent the wheel when thousand have already gone through all of this.
Thanks again!
Brian
brakes, conversion, front end, half ton, rotor
