Old 04-04-2014, 10:08 AM   #1
blazer2007
pic request for full ex.at the rear?
I,m trying to figure out where to hang my exhaust from the rearend out to the rear,how far does it hang down,does it run along the frame by the gas tank ?,where to put the hangers?There are a couple of blazers running aroun town but all their ex. run in fr. of the tires.Is a 78 if that makes a difference
blazer2007 is offline   Reply With Quote
Old 04-04-2014, 11:36 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: pic request for full ex.at the rear?
Are you trying to recreate stock or just install a good exhaust? Inside the frame rails and 90 degrees out the side under the rear leaf spring shackles is a good starting point. It doesn't have to be 90 degrees, you can do 45 for a swept tip look. The big nono is straight out the back, you'll get tons of exhaust gas recirculation inside the cab if you do this and drive with the back window down.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-05-2014, 10:13 AM   #3
blazer2007
I just want full dual exhaust,just the gas tank is so big I don,t see how you can go inside the frame,if you had to remove the tank one day you,d have to take off the ex. and I don,t want it hanging too low.Is a lowered 2 wheel dr.Even a pic of stock ex. is good ,at least I can see where they are going.
Old 04-05-2014, 10:23 AM   #4
68Timber
68Timber's Avatar
I'll get a pic today.
John
74 Honda Z50 build
Old 04-05-2014, 11:06 AM   #5
blazer2007
thanks
Old 04-05-2014, 10:09 PM   #6
68Timber
68Timber's Avatar
Time got away from me today but I'll get this for you tomorrow.
John
74 Honda Z50 build
Old 04-06-2014, 10:26 PM   #7
mm1077
Active Member
mm1077's Avatar
There are some pics of my exhaust setup in the thread linked in my signature line. Exhaust routes over the rear axle and out behind the rear tire at a 45. The pipe is probably 3 inches or so outside the tank on each side. Lowered w 4" drop leafs.
mm1077 is offline   Reply With Quote
Old 04-07-2014, 03:45 PM   #8
68Timber
68Timber's Avatar
This is the passenger side rear wheel well, the sequence of pictures goes from the front of the wheel well to the back.
John
74 Honda Z50 build
Old 04-08-2014, 09:51 AM   #9
blazer2007
Thanks,that helps alot.I don,t have the gas tank or bumpers on so I didn,t have a reference point,I should have taken more pics.
