Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 04-06-2014, 08:53 PM   #1
crewcabshorty
crewcabshorty's Avatar
07 driving lights
My 2007 Silverado classic does not have driving lights.. I would like to add factory lights if possible. Is the wiring harness already there? best bet to find a wreck?
crewcabshorty is offline   Reply With Quote
Old 04-11-2014, 06:04 PM   #2
83GMCK2500
Re: 07 driving lights
What are you referring to as "driving lights"? Roof mounted clearance lights?
If you have a 2007 Silverado Classic, your thread belongs in the other section, the GMT-800 section, 1999-2007. This is technically 2007.5+.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-13-2014, 03:06 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
I disagree, I would say that may be the right section. I am guessing that he is referring to the fog lights, that arein the front bumper. However many people drive with them on all of the time, so they may not know if they are driving lights or fog lights.
Frank
piecesparts is offline   Reply With Quote
Old 04-13-2014, 11:15 AM   #4
83GMCK2500
Bumper mounted Fog Lights, if your truck did not have them it can be a crap-shoot as to how easy it is to add them. Some trucks have the complete wiring harness with the pigtails in place, they're just taped up. Start behind bumper where the lights will mount, go up from there, find the harness, see if there is a plug taped up out of the way, probably around the area right over the frame on either side. If it is not there the easiest thing to do is to pop the fuse/relay center up, find the fog circuit, that is your power source, run it down to the fog light locations, ground the lights to the core support, and add the dash switch. Thankfully, all of the dash-to-relay center wiring is in place, all you need to do is get the power to the lights and ground them. More expensive option: GM had an accessory kit, part number: 17802547
Devin
New Daily, the '96
Old 05-09-2014, 03:51 AM   #5
83GMCK2500
Been almost a month...what's up? To which lights were you referring to?
Devin
New Daily, the '96
