Old 04-16-2014, 12:19 AM   #1
WATSON403
66 c20 build
Ok so I just bought a 1966 c20 that I'd like to kind of rat rod out and make a daily driver out of the truck is in pretty amazing condition for what I payed its got the factory numbers matching 292 with 4 on the floor with only 28k original miles but anyways I want to lower this truck put some white walls on and paint it a flat colour with shop logo on the door but the issue I think I'm gunna run into is wheel clearance when lowering it with these huge 8 lug tires just wanna se if you guys could have some input keep in mind I would like to keep this as low budget as possible
WATSON403 is offline   Reply With Quote
Old 04-16-2014, 07:34 AM   #2
Mathew21
Mathew21's Avatar
Re: 66 c20 build
Welcome, Check out this recent post by rickywideglide. He used lowering springs to drop his C20. I plan on lowering my C20 using drop spindles in the front and lowering springs in the rear.
http://67-72chevytrucks.com/vboard/s...d.php?t=624845
Mathew21 is offline   Reply With Quote
Old 04-16-2014, 09:54 AM   #3
WATSON403
Re: 66 c20 build
Ya I think he changed wheels I still have those big 17s stock wheels I'm having a hard time finding new steel rims for those darn 8x6.5 s
Old 04-16-2014, 10:11 AM   #4
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 66 c20 build
Watson! Where is Sherlock Holmes!?! LOL! Look forward to seeing some pictures of the truck! I have a 64 C-20 and I put taller tires on it and it actually makes it look lower..if that makes any sense...lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-16-2014, 10:20 AM   #5
WATSON403
Re: 66 c20 build
Like I've never heard that one before! Haha but the taller wheels for a lowered look doesn't make sense to me and I just tried to add pics but I'm on a ipad and I don't think I can
Old 04-16-2014, 10:23 AM   #6
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 66 c20 build
Well..my 64 is the stock stance and I just put taller tires on it...the filling of the fender wells makes it look a little lower.
Old 04-16-2014, 10:28 AM   #7
WATSON403
Re: 66 c20 build
Oh I see I really wish I could figure out how to put up pics the wheels on mine are huge
Old 04-16-2014, 10:32 AM   #8
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 66 c20 build
I'll post some pictures of my 64 in awhile....front clip is off so it will be hard to get the idea..but the bed is on so you'll be able to see how the tires fill the rear at least! LOL! I have 31/10.50/16.5's on it.
Old 04-16-2014, 10:35 AM   #9
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 66 c20 build
Wait a minute...here's an OK one..Could probably get away with a 2 inch drop on mine...
Old 04-16-2014, 10:44 AM   #10
WATSON403
Re: 66 c20 build
Ya man that looks great I'm having a hard time finding steel rims like that u remember where you got yours?
Old 04-16-2014, 10:56 AM   #11
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 66 c20 build
Got then from a friend..who had them on his truck..so I haven't the slightest idea. lol Those might be ford rims..but they are 16.5 inch...if you can find 16's off of any later model 70's or early 80's chevy you'll be happier..the 16.5 is very expensive when it comes to finding tires...I'm sure if you locate a junk yard 70's C-20 it'll have 16's...are yours split rims?
Old 04-16-2014, 11:21 AM   #12
Mathew21
Mathew21's Avatar
Re: 66 c20 build
As already mentioned above by T.J. try to find some 16" wheels off a newer truck. I'm pretty sure I'm right on these: 8 lug GM wheels up to 2011. Ford Wheels up to 1999 . I know Doge until at least 2006 are the same bolt pattern.
Here's my C20 with mid 1990's Chevy 16" wheels.
Old 04-16-2014, 11:23 AM   #13
WATSON403
Re: 66 c20 build
Ok awesome I'm gunna be heading down to pick n pull right when it stops snowing and warms up a bit here
Old 04-16-2014, 03:09 PM   #14
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 66 c20 build
If Mathew21 lowered his truck an inch it would probably be fine...I don't say for sure cause I've never lowered a truck.
Old 04-16-2014, 03:55 PM   #15
WATSON403
Re: 66 c20 build
I'd like to lower mine as much as possible without bagging and notching the frame
Old 04-16-2014, 04:39 PM   #16
19666Trucker
19666Trucker's Avatar
Re: 66 c20 build
Look fcutd 2500 van steel wheels, you need 16" fit the drums. Before 2008 when the lug pattern change, I made 2" blocks for back and a spring shop make me new u bolts long we, there 3/4, by 3.5"x10". Then cut 1.5 out the front springs, and cut pig tail off the rear to let them rest on the ailing arms plus being a 3/4 ton it had the helper spring in the rear, ride like a lowered little bounce. Pm me if you have ?
19666Trucker is offline   Reply With Quote
Old 04-16-2014, 07:17 PM   #17
WATSON403
Re: 66 c20 build
http://67-72chevytrucks.com/vboard/a...1&d=1397690192 ok I figured out how to put up pics here's how the truck sits right now
Old 04-16-2014, 07:52 PM   #18
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 66 c20 build
I'd do a 2 inch in the rear and one inch on the front.
Old 04-16-2014, 08:01 PM   #19
WATSON403
Re: 66 c20 build
I know some people are against it but where do you stand on cutting coils?
Old 04-16-2014, 08:03 PM   #20
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 66 c20 build
I've never done it, but people who have seem to be pleased...heating the coils might be easier, or just buying a new set of drop coils.
Old 04-16-2014, 08:07 PM   #21
WATSON403
Re: 66 c20 build
Ive heard your never supposed to heat coils it ruins the steel
Old 04-16-2014, 08:55 PM   #22
66Submarine
66Submarine's Avatar
Re: 66 c20 build
Yeah; heating the spring anneals it, and it's no longer a spring at that point. Cutting coil springs in the front is fine within reason IMO (I did it a little to even out a replacement), but in the back I think it's kinda questionable.
Why not add just 3,000LBS of gravel to the back with stock springs?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 04-16-2014, 08:59 PM   #23
WATSON403
Re: 66 c20 build
Why would cutting the rear be questionable? Do you have another suggestion ?
Old 04-16-2014, 09:15 PM   #24
66Submarine
Re: 66 c20 build
The rear springs are formed at both ends to attach to the frame/trailing arms; you'll see what I mean if you look at them. You could use lowering blocks, or pre-made lowering springs to lower the rear.
Nice truck, BTW. I'd consider keeping it kind of original myself; not many around that still even have the hubcaps on them!
Old 04-16-2014, 09:30 PM   #25
rickywideglide
rickywideglide's Avatar
Re: 66 c20 build
before my friend hooked me up with these springs, my plan was to lower rear with 97 to 06 jeep tj springs ,and cut 1 1/2 coil up front,that was gathered from info on here.right now the truck has 5 inch drop springs in rear(belltech)and i think 3 inch springs in frontName:  366.jpg
first pic is stock
rickywideglide is offline   Reply With Quote
build, c20, lower, rat rod, truck
