Old 04-25-2014, 05:12 PM   #1
thekuse
thekuse's Avatar
1969 C-20 Custom Camper
While restoring my 1969 Chevy, I noticed it used to have running boards, explaining the bolt holes I found underneath. I'm looking for any pictures of a 1969 with running boards to see if I should acquire a pair in the future. I was also wondering if anyone had some picture of the original aftermarket add-ons for these tricks as well. Thanks, Elliot
thekuse is offline   Reply With Quote
Old 04-25-2014, 05:42 PM   #2
ole dollor
ole dollor's Avatar
Re: 1969 C-20 Custom Camper
I have no pic's , but I do remember that they sold some aluminum type running boards several years ago. they made them for almost every thing.
you might try google and see if they show any..
ole dollor is offline   Reply With Quote
Old 04-25-2014, 07:28 PM   #3
SS Tim
SS Tim's Avatar
The add-on aluminum or steel running boards were a later accessory. Really a mid 70s and later sort of thing. Saw a lot of them on dually pickups as they became the "in" truck. Most of the time they end up looking like tacky add ons, being cut from flat stock and extrusions. Just about any old truck magazine will show you a set. Dee Zee comes to mind as on brand.
Now are you sure your truck had running boards? There were semi-popular camper steps that attached to the door and rode in and out of a cab mounted loop as you opened the door. They actually worked once you got past the look or actually needed them.
Running boards in general tend to be too high as an assist step and to me are more akward than useful. They do however make good splash guards.
SS Tim is offline   Reply With Quote
Old 04-25-2014, 07:47 PM   #4
thekuse
thekuse's Avatar
SS Tim, I'm not sure now. Was the second picture the camper steps or would you happen to have a picture of them?? Didn't know there was such a thing!?
Old 04-25-2014, 07:55 PM   #5
ole dollor
ole dollor's Avatar
Tim that is the ones that I remember. good pic .
Old 04-25-2014, 08:38 PM   #6
SS Tim
SS Tim's Avatar
The second picture is an automatic camper step kit.
If you look at it the tread is the piece with the beveled ends and the chromed channel mounted to the bottom of the door. The tread attached to the door channel and slid in and out on the hoop bracketed to the cab. I know I have some pictures and if necessary I can probably get a picture/drawing from a J.C. Whitney catalog. But that will have to be later.
Old 04-25-2014, 08:55 PM   #7
JDL
JDL's Avatar
The first pic is my camper and they do look all right on it and help some.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 04-25-2014, 09:21 PM   #8
swamp rat
swamp rat's Avatar
Its a 72 but they have been on my truck since my step dad bought it, pretty much in sad shape and will be removing them soon for a set of Aries step bars EDIT, Drivers side is fine, passanger side a bit mashed..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
1969, add-ons, c-20, options, running boards
