05-03-2014, 03:03 PM | #1 |
When did they switch from tower to gear clamps?
My truck only had a single tower clamp, and it was on the breather hose. By the time I got it, everything else was gear-style clamps.
My guess is that 69 was the last year of tower clamps (my 2+2 and Camaro use them). But I really don't know. Anyone happen to know?
05-03-2014, 03:23 PM | #2 |
Re: When did they switch from tower to gear clamps?
When I first replaced the radiator hoses on my 69, I replaced the tower clamps with gear clamps. I THINK the heater hoses may have been the spring type clamps. If not, they were also tower clamps. Mine now has tower clamps everyplace except for spring clamps on the heater hoses. As I recall, that's what the 69 service manual shows. Of course that could have been a carryover from previous years.
Edit: The 70 Chevy service manual shows tower clamps on the heater hoses. Jim Last edited by FirstOwner69; 05-03-2014 at 03:41 PM. |
05-03-2014, 03:49 PM | #3 |
the factory never used the gear type clamps anywheres on anything
05-03-2014, 06:48 PM | #4 | |
CLAMP, Hose 1969 2468878 - Worm type adjustable stainless strap type [Radiator - 1.75 to 2.25 range] 1969 2494772 - Miniature worm drive type (.25 x 5/8" diameter) ...and so on.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible Last edited by davepl; 05-03-2014 at 07:01 PM. |
05-03-2014, 07:03 PM | #5 | |
Even so, I kind of wonder if they'd revise drawings for a hose clamp, but they might.
05-03-2014, 09:44 PM | #6 |
I had a 53k mile 71 GMC 1500 custom with a 250 6 cyl/3ott that still had tower clamps. I believe even the heater hoses had them.
05-03-2014, 10:56 PM | #7 |
My 72 has tower clamps.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
05-03-2014, 11:25 PM | #8 | |
Jim http://67-72chevytrucks.com/vboard/s...d.php?t=558016 Last edited by FirstOwner69; 05-03-2014 at 11:32 PM. |
05-04-2014, 11:22 AM | #9 |
If you are looking for originality, the tower clamps look great. But I have found that after only a couple of hose changes through the years the tower clamps can distort and begin to leak. You tighten them, the tower stretches at the square nut corners and they can leak even more. At least the NOS clamps that I found at a Chevy dealership liquidation years ago did that.
Not saying the worm clamps don't wear, but QUALITY worm clamps would be the ones I would use on a daily driver. There is a reason you don't see tower clamps on modern cars and trucks. Just my 2¢...
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
05-04-2014, 12:38 PM | #10 | |
05-05-2014, 12:27 PM | #11 |
The '71 Cheyenne has a mix of clamps- probably from prior service work. The tower clamps take up a lot of room (and there's not a whole lotta room in modern engine compartments), the spring clamps are also one-time-usage items, at least they were when I worked for Honda & Toyota. Those nasty wire-style w/ gimmicky screw tensioner-hose clamps on just about every Asian vehicle (usually on smaller hoses) are considered one-time-usage by any Asian vehicle technician, too, but not by the manufacturers. They suck. I use screw-type for repairs & service- no problems, easy to access, cheap- what's not to like, unless you're a 100 point concours restorer.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
05-05-2014, 01:12 PM | #12 | |
Take a side cutter, cut the clamp where it goes up the tower, throw the factory clamp away, and put a worm gear style clamp back on. He didn't like paying me for warranty work so we did that on every hose we had to touch. I executed that move hundreds if not thousands of times.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
05-05-2014, 04:44 PM | #13 | |
Active Member
However, I agree with above. The first thing most mechanics and owners did when they had to do any work on an engine with factory clamps is to get rid of them and replace them with worm gear types. For anyone interested in the original look, here's some similar but not exactly like original on this site. http://www.cjponyparts.com/scott-dra...FePm7AodCBwAWg
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
05-05-2014, 09:15 PM | #14 |
My 87 truck still has tower clamps at the heater core, and what looks to be original heater hoses.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
