Old 05-08-2014, 12:01 AM   #1
CO62C10
2wd blazer brake help.
I have a 2wd cheyenne that doesn't have brake lines. I need to find a site where I can buy then since wrecking yards don't have what I need.
CO62C10 is offline   Reply With Quote
Old 05-08-2014, 02:44 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: 2wd blazer brake help.
I googled it and got a hit for a complete kit at Summit. It was for a 4x4 though it would probably work.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-08-2014, 02:53 PM   #3
CO62C10
Thanks for the reply. I hope it does fit because I wanna get my truck on the road already. I have called summit and they were unsure.
Old 05-13-2014, 11:02 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
find out about the purportioning valve on the front cross member.
soak it,most need to be replaced,check the fittings (weird size to back)
rubber lines i think would need to be longer for a 4X4,(even included?)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-17-2014, 10:45 PM   #5
rsavage
rsavage's Avatar
You don't indicate the year, but take a look at Inline Tube
http://inlinetube.com/Preformed%20Li.../CT-CAT-10.htm
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 05-17-2014, 11:13 PM   #6
CO62C10
It's a 1978 and thank you for the response.
Old 05-19-2014, 05:08 PM   #7
MalibuSSwagon
No brake lines at all???? Make some if you need it in a hurry
MalibuSSwagon is offline   Reply With Quote
