Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-12-2014, 10:56 AM   #1
scottiebyrd
1971 Blazer 4wd to a 2wd swap
I am wanting to swap my 1971 4wd blazer over to a 2wd. Is there any 2wd chassis that will roll under my blazer and bolt up? I am looking for the easiest and cheapest way.
scottiebyrd is offline   Reply With Quote
Old 05-12-2014, 12:17 PM   #2
notsolo
notsolo's Avatar
Re: 1971 Blazer 4wd to a 2wd swap
"Welcome to the Board." I think you would have to have a 69-72 2wd Blazer frame for a direct swap. Everything else would need to be modified.
notsolo is offline   Reply With Quote
Old 05-12-2014, 02:03 PM   #3
scottiebyrd
Will a 1967-72 c10 truck chassis fit under it? Ive looked at some of the 2wd kits but it looks like a lot of work and money.
Old 05-16-2014, 12:49 AM   #4
Livrat
Member #1049
Livrat's Avatar
Unfortunately the only direct bolt on OEM chassis is a factory 2WD one. the truck ones are too long,
Livrat is offline   Reply With Quote
Old 05-16-2014, 04:54 AM   #5
jjzepplin
jjzepplin's Avatar
I'm doing mine with the 4wd frame. It isn't going to be a show truck and is not original anyway. And I aint got no daggum money.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
