Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 05-14-2014, 06:27 PM   #1
gmachinz
Express Down/Up window harness
If anybody wants a color coded, labelled harness kit to convert your existing power window harness to relay triggered Express Down and/Up, I have then only conversion kit anywhere! I posted a few pics in the general electrical section but if you have any questions, ask away. Prices are as follows:
2-window relay trigger base harness $139.99
3-window relay trigger base harness $169.99
4-window relay trigger base harness $199.99
5-window relay trigger base harness $239.99
Add $29 to each Express feature you want-1 Express module converts 1 window either up or down so specify which windows and whether you want up, down or both. I can set up each window as Express Down, Up or both! Super upgrade and all wiring is clearly labelled.
The base harness is a ground trigger conversion which increases supply voltage to each door and is a recommended harness to convert to in order to take advantage of the Express features.
gmachinz is offline   Reply With Quote
