Old 05-14-2014, 06:40 PM   #1
scrappy70
scrappy70's Avatar
Cleaning Chassis
Besides scraping off the bulk of the dirt/grease, what is the best degreaser to use when cleaning 40+ years of build up on a chassis? Any help would be appreciated. Thanks.
scrappy70 is offline   Reply With Quote
Old 05-14-2014, 09:06 PM   #2
hugger6933
Re: Cleaning Chassis
Some people use oven cleaner, just hold your breath around that stuff it is tuff! I bought a TP tools copy of the Dyna zip with the wire fingers on it to do the under side of my cabs bed floor and frames with. They are real big with the Chevelle crowd on the rotisseres that have all the undercoating that has to come off that is a nightmare. I remembered that dread on my Elco, so I ordered one before I pulled my 70 cab to put it on the rotissere. Jim
hugger6933 is offline   Reply With Quote
Old 05-14-2014, 10:06 PM   #3
bigsnookmaster
bigsnookmaster's Avatar
I used the oven cleaner and a good pressure washer when I did mine. Worked well, but I had to go over it several times.
bigsnookmaster is offline   Reply With Quote
Old 05-14-2014, 10:14 PM   #4
Carmen Black
Carmen Black's Avatar
I blast with a pressure washer, then go over with a twisted wire wheel attached to an angle grinder. Will get you almost to bare metal, but it is a nasty job. Every time I do it, I swear I will never do it again.
Carmen Black is offline   Reply With Quote
Old 05-14-2014, 10:42 PM   #5
DPowers
DPowers's Avatar
You will be amazed at what a Hot Water Pressure Washer will do.
DPowers is offline   Reply With Quote
Old 05-15-2014, 12:04 AM   #6
Jfarns03
Jfarns03's Avatar
I used the harbour freight wire wheel set and it works fine. If you put the time in it, you wont want to paint haha
A place for everything, everything in its place.
Check out my build thread!
http://67-72chevytrucks.com/vboard/s...43#post6129043
Jfarns03 is offline   Reply With Quote
Old 05-15-2014, 12:54 AM   #7
frank69
Try to find a mobile co with a high pressure steam cleaner.
frank69 is offline   Reply With Quote
Old 05-15-2014, 01:23 AM   #8
leddzepp
Moderator
leddzepp's Avatar
POR Marine clean or a similar bilge cleaner are the best de-greasers and will remove 40 years of caked on junk.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-15-2014, 03:05 AM   #9
leftybass209
leftybass209's Avatar
Didn't believe it until I tried it. I second marine clean. Water based too so you don't have to fear EPA issues if you live in that sort of area. I would also second a pressure wash before marine clean. No sense wasting the product if a pressure wash can blast some chunky stuff off.
leftybass209 is offline   Reply With Quote
Old 05-15-2014, 08:45 AM   #10
71Dually
71Dually's Avatar
Kate Spade purses, matching shoes, jewelry and non-latex gloves. Bribes the wife every time.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72
1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code"
1970 Mercury Cougar "Eliminator" 351C-4V C6
1972 Ford Ranchero GT 351C-2V C6
1974 Honda XL-350
Member of the "6 C's and a D" 1-Ton Fun Club!
71Dually is offline   Reply With Quote
Old 05-15-2014, 01:19 PM   #11
scrappy70
scrappy70's Avatar
Awesome, I wasn't expecting this many responses so quick. Thank you for the advice. Time to start looking for a pressure washer, lol.
Old 05-15-2014, 02:41 PM   #12
wgeyer88
I tried just about everything that was recommended. POR15 Marine Clean is by far the best of all the chemicals.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 05-15-2014, 05:08 PM   #13
Fitz
She's a bit high maintenance isn't she? At least it's not Coach bags.
Fitz is offline   Reply With Quote
Old 05-15-2014, 10:23 PM   #14
ironbutter
I just cleaned mine a couple weeks ago. I used Super Clean, got it at Napa and it did the trick. Soaking 30 minutes then hit it with my powerwasher 4 times. What little parts were caked on good I got after with a chisel.
ironbutter is offline   Reply With Quote
chassis, cleaning
