Old 06-04-2014, 08:12 PM   #1
SPANKY1960GMC
help axle keeps coming out
Hey all
I have a 1960 gmc k1500 4x4 I think it is original limited slip rear end .The problem is every few years the axle berring gives up and the axle creeps out last time on the freeway at about 60 miles an hour .Thank god no one was hurt .I think because of tire and wind noise I am not hearing trouble until it is to late.Do any of you have a modification or idea what can be done to keep this from happening .Is there something causing berrings to flyapart? should they last I have had truck over thirty years now. I don't abuse this truck but it will spend more time sitting than on the road .
Thanks Spanky
SPANKY1960GMC is offline   Reply With Quote
Old 06-04-2014, 08:40 PM   #2
1963c-10
1963c-10's Avatar
Re: help axle keeps coming out
what rearend do you have in the truck? reason i ask is that a positive id on it might help someone diagnose the issue.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-04-2014, 08:52 PM   #3
66Submarine
66Submarine's Avatar
IIRC a GMC K1500 was a 3/4 ton that came with a Dana 60 axle, right?
At any rate, what you describe certainly sounds unacceptable, and it certainly shouldn't be regularly happening like that! It sounds like you might not even have the original axle, anyway. Is it a full-floating axle with the big hubs and eight lugs?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 06-05-2014, 12:18 AM   #4
Captainfab
60-66 Nut
If the axle/wheel bearing is failing and the axle comes out, that sounds like a Dana 44 axle, which is what I believe a GMC 1500 should have. If it is a Dana 60, what the OP is describing shouldn't be happening with a full floating differential.
Old 06-05-2014, 11:42 AM   #5
66customcamper
That bearing failure is a too-common problem with full size jeeps (wagoneers/cherokees/trucks) that use the D44.
Here's a thread on IFSJA.org (I have an '84 Grand Wagoneer) where they talk about the quality decline of Timken bearings and some other pertinent info:
http://www.ifsja.org/forums/vb/showt...rear+axle+fail
Here's a couple highlights:
"He said a common problem is people will press the bearing and collar together and it deforms the cage. I didn't know if he was right or wrong, but he took a tube, slid it over the shaft, and pressed on the bearing using the inner race of the bearing. Then he pressed on the collar separately."
"This is entirely a derivative of end play. Per the service manual, end play should be .000" to .015". My bearings are 2 years old, 5K miles and measure .310". That is huge! From what I can tell, the thickness of the outer wheel seals have gotten smaller. Most all measure .375" thick. We need to be using the National Oil Seal #9912 that measures .470" thick. It is the only one that is thick any more. A guy has a shim kit and beefy backing plates, http://www.betterscoutparts.com/Page_1.html This is a good read and why our bearings are dying. A tapered bearing should be fully engaged to last."
66 Custom Camper
327/ 4 spd.
Bone Stock, down to the split rims
66customcamper is offline   Reply With Quote
Old 06-05-2014, 12:00 PM   #6
66Submarine
I agree that's what it sounds like, but a 1500 GMC is a 3/4 ton and should have came with a D60 originally. The D44 was used under the 1000 1/2 tons. I'm guessing someone probably swapped the original axles out for half ton stuff at some point, which was why I asked.
Easy fix if that's it; just swap that lame 1/2 ton stuff out for a set of real 3/4 ton truck axles like God intended!
Old 06-05-2014, 08:30 PM   #7
SPANKY1960GMC
My bad my truck is the 1960 k1000 1/2 ton with m44r axle
first off thanks to all for the replies
scince i just rebuilt the diff I think i will try the link for upgraded retainers and seals and will mention the installation advise to my local shop
this kind of response is just what i expect from such a great forum
keep on supporting old truck smucks like me and i ll do my best to turn the favor.
best of luck to all and thanks again
Just in case do any of you know of a scrap yard( year model )donner truck with full floating rear end that would bolt up to this truck?
SPANKY
Old 06-06-2014, 12:54 AM   #8
Captainfab
60-66 Nut
A Eaton HO52 from a '60-'72 K20 should bolt up, but I would not recommend that differential. I would go with a Dana 60 or a 14 bolt, but the spring perches may need to be moved. Be aware that when changing to a full floating differential you will have an 8 lug wheel bolt pattern on that differential. Plus with a 4x4, you must match the gear ratio that you have in the front differential. The front differential will be very slightly higher geared that the rear. IE: 4.09 in the front, 4.10 in the rear
Old 06-06-2014, 12:57 AM   #9
66Submarine
Well, I have no idea what would be closest swap as far as a donor, but the full-float Dana 60 rear and the 14 bolt GM are both super common and have great aftermarket support. The problem is that those are also going to be eight lug axles, which means you'll probably want/need to swap the front along with it.
You'll obviously also need to find something that has the same gear ratio if you keep the front, but you also might want to just look at better semi-float axles which will have the six lug pattern, or could be re drilled for it.
Old 06-06-2014, 12:57 AM   #10
66Submarine
You beat me to it again, lol...
Old 06-06-2014, 11:54 AM   #11
61K10
61K10's Avatar
why not just a 12B
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-06-2014, 12:36 PM   #12
66Submarine
Originally Posted by 61K10 View Post
why not just a 12B
That's what a better semi float axle like I suggested would be, but I'm not sure if there would be a match for his front axle's ratio in the 12 bolt truck selection. And even if there is a potential combo that works, it might be cheaper/easier for him to just swap in two new junkyard axles that match.
Old 06-06-2014, 07:07 PM   #13
SPANKY1960GMC
Hey all
Thanks again
Looking at some retainer plates on ebay and noticed what looked like my plate labeled model 20
The ID plate on top of diff read" m44r " I think it was a 390 ratio, dose this mean i have a model 20 jeep dana or the m44r used a retainer simular to the model 20?
One more thing I was planning on buying the TABOR thick aluminum flat plate, will that work or do I need one that looks like a cuped model 20? dose TABOR have a cuped plate? or iam I out of luck?
do to Budgit, I need to fix this side the best way i can and watch the berrings close for any wear util I can correct the other side the TABOR sounds like way to go???
Thanks Spanky
60 gmc, axle, berring trouble, danger
