Old 06-14-2014, 06:10 PM   #1
OneTwo
Question for you air bagged guys: Gas tank?
Hey guys, I'm in the process of installing air ride on my '77 Suburban, and it's pretty apparent that when the back goes all the way down, the fuel tank will be hitting the ground.
My question is, what are you guys that are laying frame using for the fuel tank? Ideally, I'd like something that sits in the factory location but doesn't hang below the frame rails. Does such a thing exist?
My tank has been patched before and it is leaking like mad, so I'm in the market for a replacement anyways.
OneTwo is offline   Reply With Quote
Old 09-08-2014, 03:50 PM   #2
OneTwo
Re: Question for you air bagged guys: Gas tank?
In case anyone had the same question, a 25-gallon Blazer tank got the job done reasonably well. It hangs below the frame, but the remnants of the tow package installed on mine and the rear bumper hang a bit lower. Can drag tail without hurting the tank.
If you aren't scrambling to finish your truck before Rod Run like I was, I would suggest raising the tank an inch or two, just to be extra safe.
Old 09-16-2014, 04:00 PM   #3
justpball
justpball's Avatar
I Z'd the rear frame 4in which moved everything up and out of the way... But i was gonna have to move my filler neck so I made a shim for the tank to move it back down 2in so I could use the stock fill location...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 09-16-2014, 04:01 PM   #4
justpball
justpball's Avatar
Are you bodydropped or just bagged?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 09-16-2014, 04:03 PM   #5
justpball
justpball's Avatar
I also found a 4x4 suburban and took the skid plate off of it and put it on my 2wd... 1/8 in steel plating to keep from dragging tank
87 Crew SWB
Build for the crew
90 burb 2wd
