Old 07-19-2014, 09:51 PM   #1
JointTech
JointTech's Avatar
gauge cluster plastic cleaning
any good ideas on cleaning the plastic without scuffing it up or removing the painted on labels?
Are there stickers anywhere to replace the writing if it flakes off?
I have a crack in one of the scrw holes on the bezel. Any good ideas on sealing it up? I was think just super glue it. there is no gap in the crack. then sand and high build primer the whole bezel. Im not going for a real stock look. the highbuild by itself will cover the crack but ill have to remember to barely tighten that screw.
On the gauges the black paint and labels are pretty good so I just need to do the needles. they have a strange crust on them so im going to try to sand it off without touching the gauge and then paint the needles carefully.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-19-2014, 10:09 PM   #2
davepl
davepl's Avatar
Re: gauge cluster plastic cleaning
You can likely polish the opposite side, and maybe the inner parts of the printed side, with Novus or Meguiar's clear plastic polish. If you have a lot of fine scratches you might need a couple of different "steps" of products, like a cleaner and a polish.
Problem is that the lettering probably won't stand up to it. I've destroyed other clusters with a cotton ball and water (not a truck one), so it depends on how dried and dead the printing is.
The reproductions of the clear lens are actually good (and I hate 98% of reproduction parts). If it were me, and it wasn't critical to me that I had the original lens, it'd be way easier and probably more cost effective (compared to the products you'll need to clean that one) to put in a brand new one.
http://www.brotherstrucks.com/prodin...number=INSCF00
While you're in there, I lined mine with 3M foil tape (like they use in the HVAC industry for ducts, but not cloth "duct" or "duck" tape, it's very reflective). I feel it brightened it up quite a bit. You might lose the green color reflected off the back though.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-19-2014, 10:16 PM   #3
JointTech
JointTech's Avatar
i dont care about original. Im thinking of then just doing something weird and wild with it instead. I have some metal tape I could use. I was already thinking of painting it with some rustoleum aluminum I have that looks pretty shiny on my transmission.
I saw a black on white label kit on LMC but havent seen an original on yet.
72 C20 Long Bed
Old 07-19-2014, 10:19 PM   #4
elimontfort
elimontfort's Avatar
http://www.autodetailingsolutions.ne...googleproducts
This stuff works great
elimontfort is offline   Reply With Quote
Old 07-19-2014, 10:20 PM   #5
davepl
davepl's Avatar
I doubt they'll sell a separate sticker kit (they're painted, not stickers, originally) when the whole lens is only $49 in the link above.
There's a replacement cluster available with all cool new gauges that still look like retro-truck but updated. It's something like $600 or more though. In all the catalogs.
Old 07-19-2014, 11:25 PM   #6
530FF
Sanding needle would be difficult , I used MEK or acetone wet on a rag to clean needles on guauges with heavy crud , come off easy if only light surface crib I just painted over it and came out fine, got some fluorescent orange from local hobby store , painted needle with small brush and needles look great
530FF is offline   Reply With Quote
Old 07-19-2014, 11:54 PM   #7
JointTech
JointTech's Avatar
heres the flaky needle
I had this paint pen in my hand so what the heck.
You can see how much shinier the flourescent paint is
I also found these.
Amazon.com: 1969-1972 Chevrolet K5 Blazer Clear... Amazon.com: 1969-1972 Chevrolet K5 Blazer Clear...
72 C20 Long Bed
Old 07-20-2014, 12:40 AM   #8
69chevytrucker
69chevytrucker's Avatar
i think repop lens are pretty cheap
69chevytrucker is offline   Reply With Quote
Old 07-21-2014, 07:22 AM   #9
JointTech
JointTech's Avatar
this one changes the plastic
http://www.whitegauges.net/products/...ment-Lens.html
this one covers the gauges
http://www.whitegauges.net/products/...ce-Gauges.html
looks pretty cool.
72 C20 Long Bed
