Old 09-13-2014, 08:58 PM   #1
69chevytrucker
69chevytrucker's Avatar
is this rust common ???
i have a 83 blazer i plan on restoring just cut some of the carpet out of the back and found the floor rusted out by the tailgate is this common if so any tricks on how to stop it after i put a patch panel in
i was thinking on spraying bed liner maybe after the new steel is in
69chevytrucker is offline   Reply With Quote
Old 09-13-2014, 09:47 PM   #2
russgt
russgt's Avatar
Re: is this rust common ???
Yes it is common, my only real suggestion is to use lots of spray in bedliner after the repair.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 09-13-2014, 11:34 PM   #3
69chevytrucker
i just got this blazer i have a 69 c10 as well but i was wondering how is this rust happening i know from water but where is it comming from and is there a fix for it
thanks in advanced for any info
Old 09-14-2014, 10:03 AM   #4
russgt
russgt's Avatar
It is most likely caused by water and debris getting kicked up from the rear wheels and sitting up in between the floorpan and the rear crossmember. Its not an area that you can clean out real well while washing the truck.
70 stepside
76 blazer
86 Silverado
71 Nova SS
