Old 09-17-2014, 05:14 PM   #1
bL.A.zer90045
4wd to 2wd hardline brake line kits???
hello all,ive recently been taking time off of my gbodies and am showing my 86 4wd k5 w/full top coversion/2wd conversion some loveive gotten all the front 2wd suspension done(bolted on,still have to make reinforcement frame bckets)and am currently looking into getting the brake lines(hardlines)routed/connected.can i use my existing master cylinder lines as well as the prop valve(4wd)and or make unions? or would i need to purchase(find in he yard) a new set of 2wd hardlines/prop valve? im also planning on using brackets made by member 'captfab" for a reardisc brake conversion that utilize 94-97 fbody calipers.any help/pics/know-how would be GREATLY appreciated!!!
bL.A.zer90045 is offline   Reply With Quote
Old 09-17-2014, 09:17 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: 4wd to 2wd hardline brake line kits???
I don't know if the 2wd/4wd prop valves are different or not, you might be able to look them up for each somewhere like RockAuto and see if it's the same part number.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-18-2014, 08:56 PM   #3
bL.A.zer90045
cool,will do
