9\16 lug nuts
Doing the disk swap on my c20. Need 9/16 lug nuts for steel wheels. All I can find is lugs for mag wheels @ 8 dollars for 4! I need 16 total.
Anybody now a source for regular old lug nuts? I have tried pep boys, napa, and OReilly. No luck. thank u, paul ![]() |
![]() Join Date: Jul 2001
Re: 9\16 lug nuts
Try hitting a couple local body shops, tire shops or salvage yard. I've done that in the past with good luck. Usually get a full set of factory original lug nuts for less than a $10 spot. Guys changing or up-grading wheels usually don't want the old lug nuts. Good Luck
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Re: 9\16 lug nuts
Thanks for responding. I finally found them at an auto parts store called TOPs here in orange county on Lincoln and brookhurst. 1.79 a piece.
Re: 9\16 lug nuts
ouch
1970 sb stepside 4.5"f / 5"r; 350, edelbrock 4bbl 1406 650cfm; 20" Detroit Steel ambassadors ; front disc conv; '68 front clip; PROJECT taking too long haha ![]() |
Re: 9\16 lug nuts
Re: 9\16 lug nuts
would used work?
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
Re: 9\16 lug nuts
