Old 10-12-2014, 07:45 PM   #1
jsera
2.5-3" front drop: Spring or spindle
Hey guys one of the things I'm looking at doing with my new c10 is either a 2.5/4 front spindle rear spring drop or a 3/4 front spring rear spring drop. It seams to me that the 3/4 is cheaper since i dont have to buy spindles but what more is there to consider?
jsera is offline   Reply With Quote
Old 10-12-2014, 08:08 PM   #2
TwinsSpeedShop
Re: 2.5-3" front drop: Spring or spindle
spend the money on a spindle up front. you will retain some of your ride while gaining the drop. I did a 3" spring up front to start and just changed to a spindle/spring combo. It rides so much better and not on the bump stops all the time.
TwinsSpeedShop is offline   Reply With Quote
Old 10-12-2014, 08:08 PM   #3
BMERDOC
BMERDOC's Avatar
Its definitely cheaper if you don't have disc brakes. 3" spring drops in the front are fine and cost effective.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-12-2014, 08:10 PM   #4
jsera
I do have factory front disks on the truck
