Old 10-22-2014, 08:09 PM   #1
68_-c\10
68_-c\10's Avatar
lowered front suspension
I have a 68 c10 I lowered the front 3 inches with drop springs it now has positive camber I took the shims out but still positive what do I need to do?
68_-c\10 is offline   Reply With Quote
Old 10-22-2014, 08:42 PM   #2
Xeen
Xeen's Avatar
Re: lowered front suspension
There is an ongoing debate in the c10 community using stock suspension what the maximum spring drop is before the alignment geometry is nonreconcilable.
You can safely use a 2" drop spring and reconcile the geometry but anything beyond that is questionable and is at your own risk.
There is a reason several companies manufacture drop spindles.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-22-2014, 09:58 PM   #3
ujsf01
ujsf01's Avatar
I second that statement by Xeen!
Steve McMillen
ASE and GM certified Master Technician
25 years+ experience
No, I do not know it all, that's why I attend tons of training.
ujsf01 is offline   Reply With Quote
Old 10-23-2014, 07:10 PM   #4
68_-c\10
68_-c\10's Avatar
so with the suspension set up I have now I could just buy 2 inch drop spindles and be able to align it? will it lower it even more?
Old 10-24-2014, 05:05 AM   #5
mechanicalman
If you still have the 3" drop springs, and install 2" drop spindles, you would have 5" drop and the same alignment problems you have now.
Did you want a 3" drop compared to what it was before, or 3" drop compared to "stock"?
If you want 3" drop compared to stock, put in a new set of standard springs and put in a set of 3" drop spindles.
If you want a 3" drop compared to what you had before, put the old springs back in and put in 3" drop spindles.
mechanicalman is offline   Reply With Quote
Old 10-24-2014, 09:06 AM   #6
DjS71
Mechanical man laid it all out perfectly, just have to math it up.
I'm used to seeing the 2.5" spindles, so I put those and a 1" spring on mine for 3.5".
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 10-24-2014, 09:32 PM   #7
68_-c\10
68_-c\10's Avatar
ok so I think im gonna get 2.5" spindles with 1" drop springs do I need to get 3" drop shocks?
Old 10-24-2014, 09:33 PM   #8
68_-c\10
68_-c\10's Avatar
3.5" drop shocks I meant
Old 10-24-2014, 11:26 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
The drop spindle does nothing to the geometry of the suspension... It only physically moves the spindle up 2.5". The 1" drop sping changes the geometry...so with only a 1" drop spring up front you're OK running a stock shock.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
