Old 11-18-2014, 11:15 PM   #1
IronCanine
I'm trying....
IronCanine's Avatar
Looking for 1970 St. Louis VINs for Chevy Trucks built Jan/Feb/Mar '70
Hi Guys,
I've got a 1970 Blazer with a VIN KE180S1451XX. The blue build date sticker is missing and I have no other documentation to determine the build month. By using the date stamps of items original to the truck (instrument cluster 12-19-69, dash pad 12-22-69) I can guess that it was probably built in January or February of 1970 (maybe March). If any of you have a 1970 St. Louis built Chevy (VIN fifth digit=0, sixth digit=S) and you have a build date sticker in the door jam of 1/70, 2/70, or 3/70...could you post your ending VIN sequence 1000XX, so that by process of elimination we could nail down my build month.
...hope this makes sense. Thanks to you all.
IronCanine is offline   Reply With Quote
Old 11-19-2014, 02:23 AM   #2
SS Tim
SS Tim's Avatar
Re: Looking for 1970 St. Louis VINs for Chevy Trucks built Jan/Feb/Mar '70
Well done! Good Luck!
SS Tim is offline   Reply With Quote
Old 11-19-2014, 02:36 AM   #3
IronCanine
I'm trying....
IronCanine's Avatar
Thanks Tim...for the comment and your help.
Old 11-19-2014, 03:02 PM   #4
cericd
cericd's Avatar
Hey IronCanine, I have a 1970 St. Louis built pickup. It still has the door jam sticker but I'm not sure of the month. I'll check when I get home from work and report back.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 11-19-2014, 08:55 PM   #5
cericd
cericd's Avatar
I checked my door jam sticker and I have a build date of 11/69 so it looks like I'm no help. Good luck with the search.
Chris
Old 11-19-2014, 09:34 PM   #6
IronCanine
I'm trying....
IronCanine's Avatar
I'd be curious about your serial number just as a reference. What are the first for digits of the ending six? i.e. 1000XX
Old 11-19-2014, 09:40 PM   #7
cericd
cericd's Avatar
Originally Posted by ironcanine View Post
i'd be curious about your serial number just as a reference. What are the first for digits of the ending six? I.e. 1000xx
1223
Chris
Old 11-20-2014, 08:51 AM   #8
Keith Seymore
Keith Seymore's Avatar
x2
1223
Looks like we are on the right track....
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-20-2014, 10:32 AM   #9
IronCanine
I'm trying....
IronCanine's Avatar
K
Agreed...Thanks for the digits Chris.
Old 11-20-2014, 10:49 AM   #10
bruceman1968
bruceman1968's Avatar
IronCanine, here is a 1970 St. Louis door sticker. It's not my truck. But it does help.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 11-20-2014, 11:36 AM   #11
IronCanine
I'm trying....
IronCanine's Avatar
Attachment 1326733
That does. Thanks!
Old 11-20-2014, 11:41 AM   #12
IronCanine
I'm trying....
IronCanine's Avatar
Ok guys. Here's what I have so far:
September 102XXX
October
November 122XXX
December 1389XX
January
February
March 157XXX
Old 11-20-2014, 12:40 PM   #13
Keith Seymore
I would encourage you to keeping going but it seems at this point we could do some (really) rough interpolation.
I counted 45 working days between the period of September 15 and November 15, 1969 (not counting any overtime; I arbitrarily chose the middle of the month).
122,000 - 102,000 = 20,000, divided by the 45 days = 444 units per day.
As a sense check, 55.5 jobs per hour for an 8 hour day. That's a pretty good value as most of the truck plants ran, and still do run, around 60 jobs per hour. I do not know if St Louis was running one or two shifts of production at that time.
Now, even though that rate doesn't seem to hold true for the period from December 15 to March 15, I would propose we can build up from the December value of 138,900 at a rate of 444 units per day.
145,100 - 138,900 = 13 days, which would likely put the build in the mid January 1970 timeframe, assuming (again) no overtime and that the plant did not run during the time between Christmas and the New Year holiday.
Looking at it another way, 145,100 is about 1/3 of the way between 138,900 and 157,000. I count roughly 66 working days between those two values, so we could figure your truck was built approximately 22 days after 138,900. Assuming 138,900 was built on December 15 (arbitrarily) then I count 22 working days up to January 26, 1970, again assuming no overtime and that the plant did not run between Christmas and New Year.
K
1979-1986
1986 - 2019
Old 11-20-2014, 01:46 PM   #14
SS Tim
SS Tim's Avatar
Hopefully we can populate this with more data points but this is looking better all the time. So far Keith's projections are putting this in the last week of January. This is about thirty days behind the dash and cluster dates noted.
Old 11-20-2014, 03:47 PM   #15
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
This would be a fascinating reference once the data for six years times four (?) assembly plants are filled in. I nominate 1968 St. Louis to be the next candidate.
Keith:
Do all plants start at 100001 for Chevy? 152xxx would be one I'm interested in. 52,000 units / (444 units per day * 5 days/wk) = 23 weeks after the start of production. 9/15/67 + 23 weeks = the last week of Feb '68, correct?
Good work guys.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 11-20-2014, 04:11 PM   #16
Keith Seymore
Originally Posted by hounddogs! View Post
Keith:
No, not necessarily.
Bruceman is compiling a list of starting numbers by model year, plant and nameplate (Chevy vs GMC).
K
1979-1986
1986 - 2019
Old 11-20-2014, 04:18 PM   #17
bruceman1968
Hounddogs, Your asking about the 68s right? 1968 Chevys started with 100001
Old 11-20-2014, 04:51 PM   #18
IronCanine
I'm trying....
IronCanine's Avatar
K
Wow. Thanks for breaking that down Keith. It makes a lot of sense, but I would definitely like more data points. Of course any one these could have been built on the 31st or the 1st (or any day in between for that matter).
That year Christmas was on a Thursday (as was New Year's of course). Was it common to take the entire time from Christmas through New Year? My dash pad inspection date was Monday 12/22 coming from New Hampshire. A December assembly seems terribly unlikely to me.
I just would like to see some closer serial numbers, because I would not be surprised if it did slip into February.
Thanks for all your efforts.
Let's keep these numbers coming guys.
Brad
Old 11-20-2014, 05:26 PM   #19
68shortwide
68shortwide's Avatar
I'm going to be using a pretty complete 69/70 as a parts truck. I don't have it here as of yet but when it gets here ill for sure look and report back. I live in STL so I'm pretty sure itd be built here.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 11-20-2014, 05:53 PM   #20
IronCanine
I'm trying....
IronCanine's Avatar
Thanks Jack...that'd be great.
Old 11-21-2014, 08:28 AM   #21
Keith Seymore
You are welcome. I agree about the trucks being built any time during that month; I chose the middle just to make the counting easier . I don't think it affects the number of available working days but it could cause your build to slip from barely in one month into barely into the next.
Yes - GM is normally off starting with the 24th, returning January 2nd (unless it's a Friday, then return the following Monday).
This is almost a certainty for the office workers - BUT - during boomtimes (like the late 60's) the assembly plants, manufacturing plants and skilled trades would often work overtime through the Holidays.
So - no way really to know at this point, unless you can find someone who worked at that plant at that time who has a really good memory.
K
1979-1986
1986 - 2019
Old 11-21-2014, 09:04 AM   #22
hounddogs!
hounddogs!'s Avatar
Yep. Thanks for confirming.
DD '09 Pilot
Old 11-21-2014, 05:26 PM   #23
Lemield
Lemield's Avatar
Hi Brad,
Checked my 70 C20.......Sticker says built 03/70. Number is 157279.
Just for fun, checked my 71 K20 (built in St. Louis too). Sticker says 12/70.
Number is 617570.
Hope this helps.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 11-21-2014, 05:29 PM   #24
Lemield
Lemield's Avatar
Attachment 1326733
WOW...that is really close to my 70 C20....just 18 numbers lower!
Larry
Old 11-21-2014, 05:47 PM   #25
Keith Seymore
Very likely built the same day.
K
1979-1986
1986 - 2019
