Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-10-2014, 04:35 PM   #1
Jsfucttruck
Rusty 68 K20 Burb
Picked up this 68 last Friday. She is pretty rusty, but I saved her from the scrappers or just rotting away on a farm.
I picked her up cheap, she was actually a gift from my 4x4 buddies because they knew I always wanted a slant nose 3 door.
The plan is to use her as a family wagon/wheeler. I want to swap the frame with my 78K20 Burb with a 350/465/205 and 60/14 Combo with 4.56's and a detroit in the rear. I want to exo cage her and protect what body is left.
Pic's coming.
Jsfucttruck is offline   Reply With Quote
Old 12-10-2014, 04:44 PM   #2
Jsfucttruck
Re: Rusty 68 K20 Burb
[IMG][/IMG]
The way she sat when I picked her up
[IMG][/IMG]
Home sweet home
Old 12-10-2014, 04:55 PM   #3
Jsfucttruck
[IMG][/IMG]
It would appear that someone swapped out the tailgate for barn doors.
[IMG][/IMG]
It also is going to need a heater box.
[IMG][/IMG]
Old 12-10-2014, 04:58 PM   #4
Jsfucttruck
[IMG][/IMG]
[IMG][/IMG]
The bumper and grill guard is pretty straight.
Last edited by LockDoc; 12-11-2014 at 11:03 AM. Reason: Can't post a "WIW" unless you are a premium member.
Old 12-10-2014, 05:00 PM   #5
Jsfucttruck
[IMG][/IMG]
[IMG][/IMG]
Old 12-10-2014, 05:02 PM   #6
Jsfucttruck
[IMG][/IMG]
Old 12-10-2014, 05:18 PM   #7
Jsfucttruck
[IMG][/IMG]
[IMG][/IMG]
Old 12-10-2014, 05:35 PM   #8
unclefreddy
unclefreddy's Avatar
Sweet looking burb, bet that straight six fires right up. Even when they are old, rusty and beat up those chevy's still look good.
unclefreddy is offline   Reply With Quote
Old 12-10-2014, 05:40 PM   #9
Jsfucttruck
The Donor Chassis.
[IMG][/IMG]
Old 12-12-2014, 11:53 AM   #10
68panelman
68panelman's Avatar
Love that grill guard, Why the frame swap?, All the running gear should bolt in I would think, besides the offset 292 mounts.
68panelman is offline   Reply With Quote
Old 12-13-2014, 02:22 PM   #11
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
That grill guard is sweet!
68SWB4x4 is offline   Reply With Quote
Old 12-16-2014, 04:46 AM   #12
Jsfucttruck
The 78 already has a beef tubular engine crossmember, beefier frame, reinforced steering box area longer springs,(all the fuel and brake lines are rotted on the 68)power brakes. What's a few body mounts..........
Old 12-16-2014, 04:52 AM   #13
Jsfucttruck
The previous owner said the bumper was original, but I have a hard time beliving that with all the dents in this rig. Although the grille guard may be rusty, it's straight.
I will be tossing that in the pile of unused stuff, I have 2 other winch bumpers that I am going to test fit and see if I don't have to fab one. The old warn on my 78 would fit but it's not strong enough for what I am going to use it for.
Old 12-16-2014, 04:54 AM   #14
Jsfucttruck
Burbalicious..
Old 12-16-2014, 05:06 AM   #15
Jsfucttruck
That sum ***** was dirty, and she pretty much looks the same. Except I can see the rot now.
Old 12-16-2014, 05:14 AM   #16
Jsfucttruck
And then, BAM.
Old 12-16-2014, 05:21 AM   #17
Jsfucttruck
sorry about the language, I'll keep it down.
So in my blind awe when buying this I failed to see the rot before I purchased. I still would have bought it, it just sucks that I missed seeing it.
Hey, it was dark, raining, and I had been sitting in traffic for hour and a half more than I expected. I had a itchy trigger finger.
Old 12-16-2014, 01:45 PM   #18
unclefreddy
That thing is shot ......... Looks worst than my green burb ! I might have another tub I might sell on the cheap.
Old 12-16-2014, 02:19 PM   #19
Jsfucttruck
Hey, thanks................................
Old 12-16-2014, 04:16 PM   #20
justcuz
justcuz's Avatar
I would get it running and put a reliable heater in it. Then drive it for a few thousand miles and see how the body holds up. If the body mounts are shot and the floors are real bad it might not be worth saving.
Look for a G86 on the glove box door. I think that denotes a Detroit locker.
with a little work you can install power steering, and power brakes and even put front discs on the closed knuckle front axle.
I would be inclined to keep that six if it is a 292.
Is the Rockwell married to the SM420? The only draw back to the Rockwell is parts availability. The rear intermediate shaft bearing retainer is aluminum as I recall and I wore one out. It was tough to find a replacement.
justcuz is offline   Reply With Quote
Old 12-16-2014, 05:37 PM   #21
Jsfucttruck
I have no plans to use any of the drivetrain. Not even the frame. It will eventually find a good home, somewhere else.
It's a 292ci 6cyl, sm465, Rockwell t-case. Closed knuckle Dana 44, Eaton Rear.
Old 12-22-2014, 11:51 AM   #22
justcuz
justcuz's Avatar
If my recollection is correct the 68 is on a 127" WB and the 73-91 Suburbans are 129". Not a big difference, but something to consider.
Old 12-23-2014, 03:00 PM   #23
Jsfucttruck
No updates yet. Just a ton a rain. I emptied this can nov 16th and this is a shot from how full it was last week. It has since filled up more.
We really needed the rain.
Old 12-23-2014, 03:31 PM   #24
Jsfucttruck
Actually it's not too bad underneath.
I only have one mount that might give me a problem.
Pass Front
Driver Front
Pass mid ship
Driver mid ship
The rears look to be just as good as the rest.
As far as the rear locker. I can't read the tag, it is too damaged. It doesn't really matter to me, I guess it could matter to the next guy. I will inspect it before I part with it. Power steering and power brakes will come with the other chassis. I am not even going to bother with the closed knuckle/drum brake dana 44, I got a dana 60 that's going to take it's place.
My bad, it's a 465/rockwell combo.
Not going to use that either.
I have a 465 to a twin sticked 205. The plan is to eventually run a auto with a 203/205 combo.
Old 12-23-2014, 03:36 PM   #25
Jsfucttruck
Just made the call for the steel for the rocker/floor replacement. Looks like some 2"x6" .250wall is finding a home there as rock sliders.
Cheaper than replacement panels that are just going to get ruined anyway.
