Old 12-21-2014, 12:25 AM   #1
WTX-65LWB
How To: Deluxe Heater Control Lever Replacement
Hello All!
Thought I would put together a quick tutorial on replacing the levers and cables on a Deluxe Heater Control unit. Pretty simple job that can be accomplished in about an hour once the control unit is out the truck. Hope this helps!
The problem - broken soft pewter control levers in the deluxe heater control unit
The solution - replacement steel levers from Old Air and new control cables (I purchased both through LMC).
Step 1 - Remove the old cables by removing the 1/4" fasteners and retaining clips.
Note - One cable connects to the front half of the lever near the control face. It is kind of pain to get to.
Step 2 - Remove the Defrost Hose Bracket to gain easy access to lever fulcrum pin.
Step 3 - Remove the lower bracket and blower switch (the switch connects into a groove in the middle lever).
Switch Removed
Pay attention to the bushing - the Old Air kit comes with a new one but don't lose it if yours does not.
Step 4 - Remove any remaining knobs (may have to brake them to remove them).
Levers ready to be removed - notice the distortion in the soft metal.
Step 5 - Drift out the fulcrum pin (a few taps on the pin is all it takes)
Components removed.
Control Unit stripped down and ready for reassembly.
WTX-65LWB is offline   Reply With Quote
Old 12-21-2014, 12:33 AM   #2
WTX-65LWB
Re: How To: Deluxe Heater Control Lever Replacement
Part 2 - Going Back Together
Here are the parts in the kit from Old Air. It is complete and the levers are much more rigid than the original ones.
Step 6 - Assemble the lever arms and spacers. The provided instructions are good and provide adequate detail.
Step 7 - Install the new knobs (mine fit tightly on the new levers)
Step 8 - Install new cables and reinstall blower switch and brackets . The new cables are much smoother but the cable end clamps suppled were inadequate. They did not match up well with the channels in the control unit. I ended up reusing the cable ends from the original cables on the truck. Also - the cable attachment on the front half of one of the levers is a pain!
Complete and ready for reinstallation. A simple, easy improvement to get the heat working properly!
Old 12-21-2014, 01:35 AM   #3
Captainfab
60-66 Nut
Thanks for taking the time to put together this nice write up
Old 12-21-2014, 08:09 AM   #4
bj383ss
bj383ss's Avatar
Nice writeup. I will be using this when I rebuild mine later this year.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 12-21-2014, 10:28 AM   #5
WTX-65LWB
Thanks for the kind words CaptainFab!
bj383ss - Hopefully it will be a help to you. I looked for similar information before I did mine but didn't find anything so I thought it might be useful.
Old 12-21-2014, 11:46 AM   #6
chevyrestoguy
chevyrestoguy's Avatar
Outstanding write-up! I like the pictures and the attention to detail. This really needs to be included in Woogeroo's How-To thread. Maybe you could shoot him a PM? I think that he would be glad to include it. If you haven't checked out that thread, you need to check it out. It's awesome!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-21-2014, 01:37 PM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Outstanding tutorial. I will be referencing this when I rebuild mine.
Since this was very good, I have added it to the FAQ for the 60-66 area. Thanks!!!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-21-2014, 04:59 PM   #8
WTX-65LWB
Thanks chevyrestoguy! I appreciate the kind words! I will shoot Woogeroo a PM.
Thanks chevy_mike! I have taken more than my fair share of info from this site so it is nice to contribute a little!
Old 08-15-2015, 12:41 PM   #9
jeromio
How does this control mount on the bottom? I retrofitted to my non-deluxe 66 and it's just flopping around when I adjust the controls. The top screws were easy enough, but I can't figure out how it's supposed to get fixed at the bottom? I'm probably missing some parts?
jeromio is offline   Reply With Quote
Old 08-15-2015, 01:53 PM   #10
earl84
On about the 8th picture from the top, you can see a bracket the has two screws that mount it to the control assembly. The other side of that bracket mounts to the lower dash panel.
earl84 is offline   Reply With Quote
