Sheet Metal Sources
OK so my bodyman is coming over to pickup my 70 Jimmy today and wanted to get some input on sources of sheet metal….
I am going to need the whole shooting match Rockers, torq boxes, compete cab floor and rear floor, and anything else… Ive seen where people are ordering SWB floors and cutting off some to replace the rear floor - is this still the best way? Big swap meet coming up in Denver CO in a couple weeks so hoping to pickup there and save on freight costs…. Might sound like a POS but the rest of the Jimmy is solid and my target is a pitna finish on the outside but not a Fred Flintstone on the inside… Will be converting from 4x4 to 2wd etc etc - its only time and money right? |
Re: Sheet Metal Sources
Pics
pics
I just came across this one today, but the headliner portion (most likely others as well) needs additional modifications and welding
https://www.facebook.com/BowtieTruck...type=3&theater Thread on how to properly fit is here http://67-72chevytrucks.com/vboard/s...d.php?t=655031 Other than that there's the usual Auto Metal Direct and LMC. I'll be doing the same as you are soon I hope
1971 Chevrolet K5 Blazer "Betty" D.D. & W.I.P. |
#5 | |
I'm trying....
![]() Join Date: Oct 2013
Multiple vendors on this site can get you covered with this...GMCPaul's and Wes at Classic Heartbeat come to mind. Due to my geography, I used South Kentucky Classics for my Blazer bed sides. Shipping might be a factor on some pieces, so local is an option. I used AMD on some pieces because I have one an hour up the road. YearOne's main facility is even closer so I picked up a few things from them. Any decent fabricator can make most repair panels work...but it's still hard to recommend reproduction panels. Clearly I had to use nearly every repair panel they make...so I got to spread it around a bit. I think it's to the point now where you won't have to use any truck specific stuff. Good luck...it'll be awesome. Take pics and post 'em...just in case this doesn't get moved, you can turn it into a build thread. ![]()
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
