01-24-2015, 01:02 AM | #1 |
Dash Pad Removal
Hi.
I'm trying to remove my dashpad. It is stuck on the passenger side. I understand there are two "clips" under there on each side of the speaker-grate? It isn't coming out, and if I use anymore force I believe the dashpad is going to break in half. Something has already broken and fallen on the floor (looks like a plastic screw with threading on each end) and I have heard other snaps. Just what am I supposed to reach under and unscrew/disconnect before trying to pull it up and out? Thank you. IDahoMAn |
01-24-2015, 01:49 AM | #2 |
Re: Dash Pad Removal
Did you pull the a/c ducts off and did you remove the screw on the right side close to the door jam.
John 82 Chevy Silverado 350ci/TH350 |
01-24-2015, 03:18 AM | #3 | |
There is no screw there on my truck. Where it seems to be stuck is on each side of the right speaker grating at the base of the windsheild. |
01-24-2015, 09:07 PM | #4 |
Anybody else???
Or do I need to break out the circular saw?? IM |
01-24-2015, 10:36 PM | #5 |
What year do you have?
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
01-25-2015, 01:37 AM | #6 |
01-25-2015, 10:06 AM | #7 |
When you have all of the screws out the edge under the emblem should raise up with no effort at all. You have the gauge bezel removed and (I think) 4 screws from the passenger's side bottom edge, plus one in each door jam?
01-25-2015, 12:49 PM | #8 |
Post Whore
sometimes the LMC Truck website / online catalog can be useful helpful for disassembly and or re assembly
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=75 |
Tags |
dash, dashpad, pad, removal, remove |
