02-01-2015, 11:25 PM | #1 |
Replace balljoints?
I am new to the site and green to turning wrenches. I bought a 72 K10 LWB last Thanksgiving and have slowly been replacing little things here and there working up my confidence to tackle bigger projects. Today I decided to replace the inner axle seals, replace U-joints on drive shafts, and replace/repack wheel bearings and seals. With the amount of grit and grim inside the drive shaft housing and amount surface rust on the outside I thought I would replace the ball joints while everything was torn down to this point. I do know this truck was only used during hunting season and sat the rest of the year for the last 5 years, same owner since 1977. I can't see any signs of the balljoints being bad and am wondering if its would be a waste of time replacing them? If it's not a waste of time I have more questions, if it is I should have it back together tomorrow. Thank you in advance for any advice.
02-02-2015, 12:43 AM | #2 |
Re: Replace balljoints?
Jack up the front end, then grab the tire by the top and bottom. If you can wiggle it in and out, then you need balljoints.
While you're at it, grab the tire both sides, and try to wiggle it that way too. If that moves, then you also need tie rods
______________________ www.northeastrodrun.com |
02-02-2015, 01:05 AM | #3 |
No wiggle top to bottom or side to side. I guess if it's not broken, don't break it.
02-02-2015, 02:47 PM | #4 |
Sounds like you're good to go then
02-03-2015, 07:53 PM | #5 |
Look at how the top ball joints mount to the a-arm. If they are riveted they are most likely original. If they are held on with bolts/nuts they have been replaced at some point. Cutting out the rivets is not impossible but not fun either. If they are good lube em up and keep running em either way!
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
02-03-2015, 08:33 PM | #6 |
sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
02-03-2015, 08:41 PM | #7 |
I don't see any rivets and there is a nut on both the top and bottom. The top nuts are pretty rusted on, so since they don't appear to be bad so I will not mess with them. I did get the u-bolts on the short drive shaft chanced today. There is steel fitted plate on the spindle side of the shaft with a plastic washer and smaller rubber seal. Does the plastic washer and plastic seal need to be replaced if they are not torn? I did get new of the bigger rubber seal.
02-03-2015, 08:43 PM | #8 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
02-03-2015, 08:44 PM | #9 |
Since it is a K10 I am guessing it is 4x4 and has no rivets or A-arms. If you have no play I would use it as is because they are a pain to replace on a 4 wheel drive.
02-03-2015, 08:49 PM | #10 |
Thank you for the advise. They are going to stay as is for now.
02-03-2015, 08:50 PM | #11 |
Disregard my post please, rwd dude here
