Old 02-02-2015, 01:51 PM   #1
Gmcfolife
Gmcfolife's Avatar
Mar K Wood Conversion
Does anyone know if GMCPAULS wood bed instructions work with MAR K steel to wood bed conversion kits?
Gmcfolife is offline   Reply With Quote
Old 02-03-2015, 01:31 AM   #2
Lou Boffa
Lou Boffa's Avatar
Re: Mar K Wood Conversion
not exact answer you are looking for but I used Mar K bed steel with Trex decking that I milled to GMC Pauls wood bed specs. Fit like a glove.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 02-03-2015, 01:44 AM   #3
Gmcfolife
Gmcfolife's Avatar
Did you use Mar K's conversion kit?
Old 02-03-2015, 03:47 AM   #4
SS Tim
SS Tim's Avatar
What exactly is your question?
Any conversion basically changes the front bed panel, rear sill and all the the cross sills to allow for the much thicker wood floor (0.81" vs 0.052-0.066" for metal).
Mar-K's kit uses their stock replacement wood. So if you are asking if GMC Paul's wood cutting directions will work with a Mar-K conversion kit/instructions, then the answer is yes.
http://www.mar-k.com/steel_floor_to_wood_bed.aspx
http://www.mar-k.com/Catalog/PDF/Ins.../67-72conv.pdf
http://www.gmcpauls.com/47-72_BedWood_Info.htm
SS Tim is offline   Reply With Quote
Old 02-03-2015, 09:51 AM   #5
Gmcfolife
Gmcfolife's Avatar
I noticed that Mar K's wood cutting dimensions for notching is slightly different from GMC Paul's. Looks like GMC Paul's will work just fine. Thanks for the info.
Old 02-03-2015, 01:16 PM   #6
SS Tim
SS Tim's Avatar
Go to Wes' page too at Classic Hearbeat, his published cutting dimensions are there with GMC Paul's and specific.
http://www.classicheartbeat.com/bed_wood.htm
While the Mar-K's is more a rather generic "how to size wood". Note it does not specify the wood plank widths but instead is baed on direct measurements from the cross sill holes.
In any event the two important things to remember are the strips project above the wood to provide a skid surface. Plus clamp the wood into a load deck but allow movement, as wood will with temperature and humidity changes.
