Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 02-18-2015, 06:27 PM   #1
$20071k10
$20071k10's Avatar
turn signal indacator help
hey guys. need help the turn signal indacators on my 71 k10 come on when you turn the lights on. what causes this and how do you fix it?
$20071k10 is offline   Reply With Quote
Old 03-12-2015, 12:50 AM   #2
MaxxRazz
MaxxRazz's Avatar
Re: turn signal indacator help
if they are on the dash solid but still flash when the indicator is turned on check the bulb mine recently started to do it. my marker light is out but the blinker filiment is still fine
MaxxRazz is offline   Reply With Quote
Old 04-12-2015, 04:40 PM   #3
jim ellis
jim ellis's Avatar
could be a bad ground in the turn signal lamps
jim ellis is offline   Reply With Quote
Old 04-21-2015, 12:46 PM   #4
ls69chevy
having the exact same problem
ls69chevy is offline   Reply With Quote
Old 10-10-2016, 04:37 PM   #5
rcm1958
replace the turn signal switch. I just had the same problem and this fixed it.
rcm1958 is offline   Reply With Quote
Old 07-14-2017, 07:37 PM   #6
RogerKoop
RogerKoop's Avatar
This usually happens when the dash harness ground is loose or has come lose from the dash lip close to the ignition switch
Roger Koop
RogerKoop is offline   Reply With Quote
