Old 02-26-2015, 01:08 AM   #1
tazzman
Volvo electric fan install with custom aluminum shroud
I used a Volvo fan because I could unbolt it from the factory plastic shroud. Its the same motor as a Taurus fan but it is bolted to the shroud instead of molded to the shroud. I used the Volvo 2 speed relay along with a 2 speed temp switch ech fs151 installed into a custom made thermostat housing. Previous owner installed a custom rad that was just tie wrapped in position so I made custom brackets for it as well. In low speed I can barely here it running. Still debating if would be better to have the temp switch on the rad versus the thermostat housing.
tazzman is offline   Reply With Quote
Old 02-26-2015, 08:15 AM   #2
yuccales
yuccales's Avatar
Re: Volvo electric fan install with custom aluminum shroud
That's some nice work.
yuccales is offline   Reply With Quote
custom, electric fan, volvo
